knowledge needed
Old Aug 11, 2019 | 10:36 PM
84lover's Avatar
84lover
Default knowledge needed
Will someone please educate me on 350 heads so i can make an educated dec ision about head swap for crossfire...84
Old Aug 12, 2019 | 01:18 AM
Hot Rod Roy's Avatar
Hot Rod Roy
If you're looking to upgrade, but still want iron (economical) heads, here's some info. Any heads you choose will need to have the exhaust port crossover passages for your EGR to work. Most aluminum heads don't have that crossover port. As you probably know, the stock heads on our '84's are the "624" casting number.
Old Aug 14, 2019 | 07:21 PM
84lover's Avatar
84lover
thank you
Old Aug 14, 2019 | 08:41 PM
Hot Rod Roy
Did that video raise more questions? What are you trying to accomplish?
Old Aug 14, 2019 | 10:01 PM
Kevova's Avatar
Kevova
Of the commonly available stock heads, GMPP Vortec with standard intake bolt location is among the best choices. It's the most up-to-date techology wise. Aftermarket is more about budget. The stock crossfire intake base will need reworked to take advantage of better flowing heads. Renegade intake is another option.
Old Aug 15, 2019 | 12:55 AM
Hot Rod Roy
If you need to maintain your EGR, you might notice that the Vortec heads don't have the exhaust crossover ports.
Old Aug 15, 2019 | 11:13 PM
84lover's Avatar
84lover
I want to keep this car in this engine (for now). I plan to open the intake...change the heads....add a cam ( I dont know what cam yet....open for ideas). I just want to open the motor up so it can move the air it's capable of which will maximize it's potential.
I already added headers.....opened the exhaust with straight pipe out the back'
working on forced air into the intake by opening it up at the hood.
upgraded the ignition
replaced dana 38 with dana 44
need to replace plugs and wires....any suggestions?
the car already runs great
Old Aug 16, 2019 | 12:52 AM
Hot Rod Roy
Originally Posted by 84lover
. . . working on forced air into the intake by opening it up at the hood. The car already runs great
"at the hood"? Are you thinking about adding a high rise hood or a scoop? Your ideas are a bit nebulous, but if you're talking about cutting a hole in the radiator shroud, the '83 prototype had that opening, and the engineers decided too much rainwater got into the air intakes, so they closed that opening. That might be okay for a dedicated fair-weather driver, but your state isn't known for its fair weather! An easy improvement is to modify the RH air filter housing inlet flap so it stays open after the engine warms up. That flap in the RH inlet normally only opens at full throttle!
Old Aug 16, 2019 | 04:09 AM
GregMartin's Avatar
GregMartin
If you don’t have to pass emissions testing then you can choose after market alloy heads.
you can check out what I did with my L83 here
https://www.corvetteforum.com/forums...e-journey.html
I thing the cold air induction mod you are talking about is cutting an oval in the plastic panel forward of the radiator support. This allows cold air to flow through the 84 bonnet ducts and into the air cleaner intake. I have this mod and it works very well. It was already done when I bought the car and I thought it was factory until I looked more closely.
Old Aug 16, 2019 | 01:41 PM
84lover's Avatar
84lover
yes...it does seem to adds a little pep./....but like roy said water in take at high speed does seem to be an issue.....but not enough to close it off
Old Aug 16, 2019 | 01:42 PM
84lover's Avatar
84lover
i am considering venting the front plate and tunneling air from there but am concerned i am amplifying the water issue
I read somewhere there was a freezing issue at the TB also
Old Aug 16, 2019 | 01:45 PM
84lover's Avatar
84lover
thanks for the flap issue...I did not know when they open
Old Aug 16, 2019 | 02:25 PM
Kevova's Avatar
Kevova
3.54 or 3.73 gears will increase SOP pep better than a new top end
Just sayin
Old Aug 16, 2019 | 11:25 PM
84lover's Avatar
84lover
the video answered alot of questions
I am trying to maximize air flow
Old Aug 16, 2019 | 11:26 PM
84lover's Avatar
84lover
what gear is in my dana 44?
Old Aug 17, 2019 | 02:27 AM
GregMartin's Avatar
GregMartin
I don’t think there will be an issue with ingesting water. My car has been driven in the rain plenty of times. And what about all those forced air induction muscle cars of the past with ram jets and cobra jets etc. Having said that I have found leaves, polystyrene and other crap in my air box. I might look at putting a bit of mesh over the hole.
Old Aug 21, 2019 | 03:59 PM
84lover's Avatar
84lover
what gear is in my lt1 dana 44?
Old Aug 21, 2019 | 04:17 PM
Kevova's Avatar
Kevova
Lt1/4 3.45
To knowledge needed
