Has anyone ever had any luck rebuilding your own 700r4 Tranny? Mine is finally out and I have found some rebuild kits and was wondering if it is something I could do myself. I am mechanically inclined.... :confused: :)
Rebuilding an automatic is best fit for a pro, its not for a rookie. Your hands must be perfectly clean and you cant get dirt inside an automatic, plus if you havent messed with one before you can get confused easy.
Id let a pro do that one. Do anything else yourself, but not rebuilding an A4.
From: Godspeed Mikey Hogsmak Invitational Spring Skyline Drive Corvette Cruise
Cruise-In I Veteran
Cruise-In II Veteran
Re: Anyone ever rebuild....... (vader86)
I agree, I rebuilt a trubo 400 twice back in 82 because I kissed it up the first time :eek: :cry :reddevil :nopity
Just had mine rebuilt by a shop other Vette owners recommended. Glad I did. Total cost with replacing the torque converter was under $1200. Got an upgraded pump and upgraded valve assembly.
I am fairly good mechanically, but I am not set up to remove a tranny properly. So, if I messed up a rebuild, it would really be a major effort to pull it again.
As it is now everything is working great and if it messes up I will let the shop take care of it under warranty. :yesnod:
I would agree with previous posts. First you need all sorts of special tools, Then you need to know how to assemble all those many many parts just right, with the proper spacings, etc. Even a good shop can mess up a 700R4. If your determined, I know that pat at http://www.levelten.com sells an instruction manual and a video tape. Your case for your tranny is very valuable, I had trouble locating a donor case when mine went south last year. thats my 2 cents worth.
BTW: The only special tools you really need are a seal resizer and a reverse piston removal tool ( I improvised both of those from common garage stuff ).
The seals can be resized with a hose clamp and shim stock, and the reverse piston can be removed with a threaded rod, a round steel plate with a hole in it and a couple of nuts.
Other than that, read an ATSG techtran manual ( actually, there are 2 for the 700R4, one is an update book ). Anyone mechanically skilled can do it...and if you run into problems, a real trans tech is always willing to help a person trying to learn...well, almost any...there are some jerks out there.
