IAC gasket
Old Aug 16, 2019 | 09:59 AM
fredk's Avatar
fredk
Default IAC gasket
I took my throttle body off my 93 to clean and install new gaskets. I got a set from Jegs, I purchased a new IAC as well. The IAC didn't come with a gasket and I can't find one anywhere. I called BBK and Jegs and they have no gasket available. Where the hell can I get one.
Old Aug 16, 2019 | 10:24 AM
AAFC's Avatar
AAFC
Emerging Vendor
Default iac gasket
Try jerrysgaskets.com , they have a lot things for the LT5 motor. But they do have IAC gasket, the gasket should be
the same for all throttle body's about $2.25. give them a call.
John
1990 white/black ZR-1
one of a few Auto eq (4L8OE) ZR-1's
Old Aug 17, 2019 | 09:54 AM
fredk's Avatar
fredk
Thanks AAFC, checked the website and they are only ZR1 parts. I wonder if they use the same IAC ?? I ordered it from Corvette Central, the say no gasket is required but the original IAC had a gasket.
Old Aug 17, 2019 | 10:37 AM
AAFC's Avatar
AAFC
Emerging Vendor
Default IAC gasket
I did a search for 93 throttle body rebuild kit. I found this, corvettepacifica.com they had a gasket throttle body rebuild kit 85-93
which includes the IAC gasket. check it out it might be what you are looking for. item # E21383
good luck
John
Old Aug 18, 2019 | 09:31 AM
fredk's Avatar
fredk
Thanks again AAFC I will check.
Old Aug 19, 2019 | 09:20 AM
puterami's Avatar
puterami
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
2020 C4 of the Year Finalist - Unmodified
2019 C4 of Year Finalist (stock)
Looking at RockAuto they are two different parts. Not only different gaskets, but different connectors.
ZR1:
https://www.rockauto.com/en/moreinfo...41343&jsn=1087
LT1:
https://www.rockauto.com/en/moreinfo...41332&jsn=1150
Old Aug 19, 2019 | 12:50 PM
fredk's Avatar
fredk
Thanks very much guys. I am in Canada so no Rock Auto will check the other sights.
Old Aug 19, 2019 | 01:56 PM
WW7's Avatar
WW7
Get a sheet of gasket material and a exacto knife and cut your own.. I do it anytime I need a gasket thats hard to find...WW
Old Aug 20, 2019 | 09:26 AM
fredk's Avatar
fredk
I thought of that but didn't know what material to buy. Choices were paper or cork. Going to order from Corvette Pacifica
Old Aug 20, 2019 | 10:43 AM
WW7's Avatar
WW7
Use paper on.newer motors, cork is for some applications from the 50s ,60s and some 70s cars. I also cut some rubber gaskets..... ...WW
Old Aug 20, 2019 | 10:47 AM
PacerX's Avatar
PacerX
I think the gasket set I just bought has one that I don't need. I'll check tonight.
Old Aug 21, 2019 | 09:00 AM
fredk's Avatar
fredk
Thanks for the replies, I ordered from Corvette Pacifica yesterday.
Old Aug 21, 2019 | 07:13 PM
krackenvette's Avatar
krackenvette
I know years ago someone on here put out the GM part number for that gasket. It was couple bucks.
Old Aug 21, 2019 | 07:30 PM
krackenvette
I found the original gasket number. Fits many GM models. Simple round gasket. Also, many vendors that sell IACs, have gaskets with them.. I would call or get another one from like RockAuto for example.
GM 25530697
To IAC gasket
