Brake Pads
Old Aug 16, 2019 | 09:45 PM
SloJo's Avatar
SloJo
Default Brake Pads
I just bought a 1993 Corvette Convertible with 16,100 miles on it. It has the original tires and brake pads. The tires are cracked everywhere and I am going to replace them. My question is, should I replace the brake pads? Can they deteriorate with time?
Old Aug 17, 2019 | 05:06 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
Yes Moisture will get between the pad and the metal it is bonded to causing the pad to separate, I had this happen to mine when I first got it, the pads looked fine mounted in the calibers but when I removed them the pads fell right off the metal they were bonded to. My 90 C4 did have a lot of miles on it and was not well maintained though. still even though your C4 has low miles on it the pads are still getting pretty old so I would at least have the pads removed and inspected.
Old Aug 17, 2019 | 11:16 AM
SloJo's Avatar
SloJo
Thanks, eutu1984. I will take them out and look at them. What brand of pads do you use on your Vett?
Old Aug 17, 2019 | 11:39 AM
eutu1984's Avatar
eutu1984
Hawk HPS with high carbon slotted rotors.
Old Aug 17, 2019 | 01:15 PM
KurtK's Avatar
KurtK
Another vote for Hawk HPS pads and slotted rotors. Have them on my 94 Vette and 2002 Camaro SS.
FWIW I was using HP+ pads, which had great stopping power. At the time my 94 was a daily, or almost daily driver. The creaks and groans of the HP+ pads got to be annoying in the predictable continuous stop and go traffic in Silicon Valley.
However I did keep the HP+s and now contemplating putting them back on sinceI live out in the sticks and my Vette is used infrequently for pleasure driving.
To Brake Pads
