92 coupe cowl shake.
Old Aug 18, 2019 | 01:19 PM
rappini's Avatar
rappini
Default 92 coupe cowl shake.
I was informed that to eliminate cowl shake when I take the Targa top off that I can get the cross member from a C-4 convertible and install on my 92 to stiffen the shake.
I guess I'm looking for confirmations that his is a possibility or other methods that can reduce or eliminate the shake.
Thanks in advance.
Old Aug 18, 2019 | 02:25 PM
Haggisbash's Avatar
Haggisbash
There is or was an alternative to the convertible cross member, it is a kit that was developed by Gordon Killebrew, reading up on this it claims to be superior to the factory system (Killebrew previously worked for GM but I understand they didn't want to pay him royalties for his system). Have a look here -
https://www.google.com/url?sa=t&rct=...wXXyvEpQYyndOT
FWIW I had the roof of my C4 for the first time yesterday to change the weather seal above the drivers door. I must say the car flexes a lot more than I expected plus there is a very unpleasant pulsing of air pressure in the cabin, I understand this can be alleviated by using a spacer that latches the rear hatch open slightly.
Old Aug 18, 2019 | 03:58 PM
KurtK's Avatar
KurtK
You may want to see if you can find a roof brace/ targa truss somewhere. Corvette Central shows one in their downloadable catalog, around page 144. However it is not searchable on their website. maybe a call to them.
These used to be fairly popular, when the C4s were much newer. You may be able to find a used one.
If you read through the history of the C4s, you may find out that they were supposed to have a T-top- which would have included a brace to the windshield header.
However, esthetics won out over function. I took the roof off mine a few times, wasn't worth the compromise.
Old Aug 18, 2019 | 04:32 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Old Aug 18, 2019 | 06:46 PM
krackenvette's Avatar
krackenvette
Originally Posted by FASTAZU
I have one of these and will not go topless without it.
https://www.corvetteforum.com/forums...e-is-here.html
I got the other version of this from RD Racing. Not as pretty as they used square tubing for the construction.
I also have RD Racing chassis stiffner which is a bolt in 4 point. It helps allot. But the roof brace really makes a difference.
Old Aug 18, 2019 | 09:26 PM
CorvetteRules's Avatar
CorvetteRules
While I can feel more flex with the top off it doesn't stop me from enjoying every chance I get to ride topless. I didn't buy my Corvette to go road racing.
Old Aug 19, 2019 | 10:37 AM
rappini's Avatar
rappini
Hagg, thanks for the information I think that is the way I'll go just have to save up some more shekels. Thanks again.
Old Aug 19, 2019 | 10:38 AM
rappini's Avatar
rappini
Thanks for the info.
Old Aug 19, 2019 | 12:54 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
If you do end up using a factory X-brace, just be aware that you will lose some ground clearance. Boxing in a factory brace would make it even more effective.
Old Aug 20, 2019 | 06:02 PM
SJW's Avatar
SJW
Having owned both a coupe and ragtop C4, I can confirm that the coupe gets very loose structurally when the targa panel is removed. And wind turbulence in the cockpit is just awful. I removed the targa on mine once, and almost immediately decided that I'd never do it again.
The factory X-brace under the ragtop car does help quite a bit to stiffen the structure, but there's still a bit of cowl shimmy, most noticeably when the ragtop is down. The X-brace doesn't completely eliminate the jitters. And, as pointed out above, it does cost you around an inch of ground clearance. My car has high-centered many times as a result of the reduced clearance.
Live well,
SJW
Old Aug 20, 2019 | 06:19 PM
krackenvette
The C4 was never designed to be a ragtop or a Targa. It was then cut into both and it shows. Take the roof off and jack it up. Try to open the door. With my RD Brace, I can now. The aftermarket companys offering roof braces are a God Send..
Old Aug 20, 2019 | 08:40 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Old Aug 21, 2019 | 10:00 AM
rappini's Avatar
rappini
Thanks I learned somethin new about my C-4.
To 92 coupe cowl shake.
