Let's talk 1985 ECM replacement...
1. Are these things true?
2. If so, which years are better?
3. Are those years direct plug and play? No monkey business moving wires around in connectors and such?
2. If I wind up changing I'm going with https://www.dynamicefi.com/
3. No, nothing is plug and play without having to do wiring work.
What are you looking for? If the car is still fairly stock (minor bolt ons) the 85 is fine. If you are doing FI, Cam, engine swaps, etc then the 85 is limited. I just had mine tuned by TPIS for my ZZ4, miniram car. It runs pretty good. Not perfect but good. In the process I almost went with the Dynamic EFI as I was having some challenges getting my tune from TPIS. They had some issue with their software and hardware to do the tune which now require a different socket to be solder in if you go that route. I already know, that if I want to do any more tune work on the car I'm just going dynamic EFI as I want my dash to work properly but have a system that is easy to tune as well.
Only real other options is the 86+ ECU swap (takes the same work as the dynamic system so why bother IMHO) or go full stand alone.
