94 Corvette Throttle Body
Old Aug 22, 2019 | 06:17 PM
Edmund065's Avatar
Edmund065
3rd Gear
Default 94 Corvette Throttle Body
Looking around for an original throttle body for my 350 TPI LT1. Have been offered a TB from a Camaro. OEM part number is 17094051 whilst the replacement part on offer is 17104417. Any advice appreciated on either the use of the Camaro TB or alternatively, availability of the correct part.
Old Aug 22, 2019 | 06:29 PM
Scott442's Avatar
Scott442
Original engine in a '94 would be the LT1. I bought one from this seller and will probably buy a spare for future use.
https://www.ebay.com/itm/LT1-5-7-Thr...IAAOSwcB5Z5OA6
Old Aug 22, 2019 | 06:33 PM
Edmund065's Avatar
Edmund065
3rd Gear
Thanks very much for that. Interestingly enough, that's the exact one I was looking at/ enquiring after. So no problems with it from your experience?
Old Aug 23, 2019 | 08:08 PM
Scott442's Avatar
Scott442
No problems at all. Car idles a lot smoother and at a lower RPM than before. The throttle cable bracket is different than the original one but I adjusted the cable and verified full throttle. I may eventually swap brackets once I find instructions on how to do it.
Old Aug 23, 2019 | 10:00 PM
Edmund065's Avatar
Edmund065
3rd Gear
Ok thanks, much appreciated. Will go ahead with that then.
Cheers.
To 94 Corvette Throttle Body
