driving lights
Old Nov 11, 2002 | 05:50 PM
brookman's Avatar
brookman
Default driving lights
I replaced both bulbs in the fog/driving lights. THey still dont work. Does anybody have the wiring diagram? I checked the fuses - are these controlled by a relay? I have the CD with the wiring diagram and it isn't very useful.
Old Nov 11, 2002 | 06:11 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: driving lights (brookman)
There is not separate fuse for the fogs, they are powered directly through the headlight switch, the Fog Light Swith and on to the fog light bulbs.
Old Nov 12, 2002 | 01:49 AM
ddsovy's Avatar
ddsovy
Check the ground wire. also do your headlights work?
Old Nov 14, 2002 | 12:52 PM
brookman's Avatar
brookman
Default Re: driving lights (ddsovy)
Yes - everything else upfront works great.
Old Nov 14, 2002 | 01:01 PM
65Z01's Avatar
65Z01
In that case pull the fog light switch and see if it's getting power in either park or head light position.
Old Nov 14, 2002 | 01:11 PM
92TripleBlack's Avatar
92TripleBlack
Test the outlets. See if you are getting power there with a test light or meter first. If not, track the wires back. Silly question, but you do have the switch pushed below the headlights to turn them on and its lighting up right?
Old Nov 15, 2002 | 12:28 PM
brookman's Avatar
brookman
Default Re: driving lights (92TripleBlack)
You mean the switch off to the right? I have tried it in all three positions far right (off) middle (on?) and far left (momentary?) and with the headlight switch in all positions. I guess I am going to have to pull the dash off again and look at it.
To driving lights
