Well, I had an incident the other day where the brakes got real lite. Felt like I had a leak. Pulled over, no leaks, and the master cylinder was full. An older gentlemen came over and asked what happened. I explained and he said air in the system.
But, not at that time. I pushed on the brake pedal and master cylinder moved to the right. The inside nut was loose. Wierd to most, but not to me. (long story short, I did not tighten it a while back when I was going to R&R the booster.) tightened it up and pedal was fine.
Well, today when the car got real fricking hot, 235, oil 250 in stop n go with ac on.. The brakes did the same thing. So, I pulled over, and pulled the master cylinder cap off, and it had a little bit of foam looking substance on the caps rubber. Fluid was black as hell. Air in system? I did brake bleeding years ago, but manually in garage.. Should I have them done a different way?
Master cylinder is new GM, braided lines. About 2 years old, less than 3000 miles, but all city. I have Hawk HPS pads, C5 front brakes.. Brakes fine, pedal has always, since 1996 (second owner on 93) been hard.
When I start car, pedal goes down, but pumps up quick. Vacuum to booster is about 14inches. Cam/396 lopey..
Moisture in the fluid will boil and cause a low pedal. Then when it cools it will seem normal again. If the fluid is black, you need to bleed the entire system. Then exercise the ABS and bleed some more.
