Cluster problem
Old Aug 27, 2019 | 10:48 AM
Veeku's Avatar
Veeku
Default Cluster problem
Hello,
Can anybody help with this my blinking cluster?
What can be a problem? I did order that cluster about 3 years ago (repaired). Old one get smoke out (power unit from cluster)
Is it time for new again?
https://vaksela.kuvat.fi/kuvat/Corvette/IMG_7335.MOV
It works long time with no problem, sometimes it will do that.. and no rpm or vss connected, but still when you drive, it will do that sometimes...
Old Aug 28, 2019 | 09:16 AM
WW7's Avatar
WW7
If the cluster is blinking on and off, it sounds like bad solder joints on one of the circuit boards.. Over time the joints crack and break and need to be resoldered... Go to this link http://batee.com/ and look up your problem and how to repair it. This guy is the master when it comes to C4 clusters...WW
