Which Walbro Fuel Pump?
Old Nov 11, 2002 | 09:35 PM
No Go's Avatar
No Go
Default Which Walbro Fuel Pump?
What fuel pump do I want?
I want a simple BOLT IN upgrade to the stock 81,000 mile fuel system.
Walbro seems to be highly recommended brand, but which one? I see racetronix offers a GSS307 and GSS340. Seem similar except the 340 is capable of high pressures. Is there any negative by running the 340 even if it is below the high pressure rating? (For instance in case nitrous is added to the combination)
Thanks for the help.
Old Nov 12, 2002 | 08:52 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Which Walbro Fuel Pump? (No Go)
These are both 255LpH right? if so I am running the 307 without troubles and I know MVR 155 is using the 340 in his GS without problems either
Old Nov 12, 2002 | 01:08 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Which Walbro Fuel Pump? (-=Jeff=-)
They are identical pumps until the pressure goes over 50psi. Then the 340 continues to flow well, whereas the 307 poops. Unless you plan to run massive pressures or a power adder such as dry nitrous or a blower, then the 307 is a suitable pump (even for wet kit nitrous).
Old Nov 12, 2002 | 02:42 PM
TIMSPEED's Avatar
TIMSPEED
Would I need to upgrade my fuel pump in my 87? I'm going to be adding a Nitrous Plate (It's a wet kit I guess, because it introduces fuel & nitrous) I have a 2 year old stock fuel pump in it now. On a recent dyno, my A/F Ratio was basically 12.8 throughout the entire rpm range. :cheers:
Old Nov 12, 2002 | 05:07 PM
Red Rocket's Avatar
Red Rocket
Put the 307 in my 396. Same as 340 to 55PSI.
Old Nov 12, 2002 | 06:03 PM
No Go's Avatar
No Go
Thanks folks.
I think I will go with the 340.
To Which Walbro Fuel Pump?
