1991 Brake Line Replacement
Old Sep 17, 2019 | 12:19 PM
littleredcorvette88's Avatar
littleredcorvette88
Default 1991 Brake Line Replacement
Looking to replace the brake lines and was wondering if anyone has completed this job yet? If so how difficult of a project would it be to complete and what kits have you used? Looking for pre-bent kits.
Any info would be great!
Thanks!
Old Sep 17, 2019 | 01:05 PM
ChumpVette's Avatar
ChumpVette
Which ones?
Rubber lines at caliper. Easy.
Hard lines on frame. Pain in the ***.
Old Sep 17, 2019 | 07:04 PM
zachaeous's Avatar
zachaeous
Brake line kits are very expensive as you probably already know.. I purchased a set back in the 80s for a 59 and it was over a 100.00. It was a very simple kit compared to your 91. I looked up a kit for the 91 and the steel lines were 299,00 and the stainless set was 329.00. The set for my 59 was accurate and only the longer lines were bent over in half for shipping. The lengths were great and all the fittings had the proper fittings.
The ABS system is a lot more complicated and I would agree with the above post. I would not consider the cost for having piece of mind when applying the brakes.
Good luck with your repair
Old Sep 18, 2019 | 04:47 PM
ctmccloskey's Avatar
ctmccloskey
I have a 1988 Coupe and for some reason the brake lines had corrosion on them within inches of where they went into the Box that contains the mechanics of my ABS system. One day I was testing them and sure enough the brake went all the way down to the floor and I was glad to be in the driveway in front of my garage.
Classic Tube up in New York makes reproduction lines and sells them for about $200.
You can get a perfect fitting set of brand New brake lines in a matter of a week or two. If you prefer S.S. they will be happy to do that for you. They are not "easy" to replace in your driveway but if you are creative and want to save a few bucks it can be done, I raised the Car up and put it on stands and then remove wheels and do whatever is needed. Your set is the same as the 1988 as they have us listed as 88,89,90,91 which I know is incorrect. That explains why I had extra parts that did not line up or match anything on my 1988 C4. The 1988 has a one year only master cylinder and is a very primitive version of anti-lock brakes. The hardest part for a lot of folks is bleeding all the air out. I use a reverse pressure bleeder and it makes the job much easier.
Classic Tube also makes the rubber brake lines for between the car and the caliper, your choice or original or SS braided hose. The SS makes the brakes allows for a better pedal feel. The standard rubber lines there need to be replaced on many old cars as it swells up and absorbs the pressure of the brake fluid instead of pushing the brake piston like it supposed to be doing. I have them on both my Corvettes. The products that Classic makes are D.O.T. approved where some other brands are not.
Best regards,
Chris
Old Sep 18, 2019 | 07:38 PM
aklim's Avatar
aklim
Would it not make the job easier if buy a roll or two of NiCopp line to do the job? Flex lines I would get a brake hose kit.
To 1991 Brake Line Replacement
