C4 Coilover Spring Rates Autox/Track
You're making things up in your head. What does "translates the shudder across the car"...even mean? The car "shudders" b/c the structure isn't stiff. A C4 will always "shudder across the car" in some situations, b/c the frame isn't as stiff as we'd like it to be.
How is the rear independent? It's not...b/c of the sway bar...but if you remove the sway bar, it is b/c the mounting of the rear spring is in the center of the car. The mounting is such that action on one side of the spring, has no meaningful effect on the other side of the spring. Each side of the spring behaves just like a single, independent spring -like a coil spring.
The front mounting, which is widely spaced, produces some anti sway bar effect -the purpose being to reduce the requirements (size and weight) of the sway bar. If you change to coil overs that have the same wheel rate as the stock spring, you'll need to add more sway bar, or you'll experience more body roll.
The reasons that you think exist are not reasons to $witch to coil $springs. There ARE good reasons to switch. The reasons that you you're citing, or not legitimate reasons.
Thank you for the lesson in Corvette vehicle dynamics. Does the adjustable suspension offer better street ride.
I have old bushing and stuff. Will changing them improve the ride. I have new Billstien shocks for the Z51, which is the proper shock for this car.
Thanks again
I've never driven a C4 w/the adjustable suspension...and tried it on anything other than the "perf" setting. In that mode, it felt similar to my '92 which has Koni shocks.
Old bushings definitely do not help. Changing them and having GOOD/new shocks will help. Stiffening the frame will help. I have an RD Camber brace. It's helps.
Jseremba, Tom is on point. A spring is a spring: it does the same thing no matter whether it's a coil or leaf or torsion bar. Honestly, trying to define "independent" suspension in the way you're talking is not technically correct, and even with swaybars or whatever, these remain fully independent. It's only not independent if the wheels are rigidly tied together, as they are with a solid axle. That is, in a solid-axle car a change in camber or toe on one side necessarily requires an equal change for the wheel on the other side, regardless of whether the body moves or not. This is not the case for any C4, regardless of what springs it has or whether or not it has a swaybar. The term "independent" was not intended to refer to wheel loads, which is what you're referring to.
The best way to think of this is to boil it all down to wheel rates and wheel loads: what is the total rate (spring plus swaybar rate multiplied by the motion ratios squared) at each wheel, and what happens to the loading on one wheel when the load changes on one or more other wheels? Regardless of what kind of springs you have, and whether you run a swaybar or not, the exact same thing happens. If the load changes on a tire on one side of the car due to cornering or a bump, it must change an equal and opposite amount on the other side. This cannot ever be any different. It's also the same regardless of the type of suspension. So it's impossible for a leaf spring to be harsher in ride quality or to handle differently than a coil spring.
Here's an article that explains more: http://www.route66corvetteclub.com/d...%20Springs.pdf
If the doc is still editable, I'd suggest two things:
1. The C2/3 were actually 3 link rears; there was no toe-rod link since the trailing arm (sort of) set the toe.
2. When defining the coil spring, you were so close, but didn't mention it; a coil spring IS a torsion bar spring, wound up.
It was a mind-**** when I read that the first time....but as I worked it out in my head I realized that it was true. The bending of the bar isn't where the majority of the force is, in a coil spring. You actually are twisting the bar, when you compress the spring. Each part of the coil is perpendicular to another part of the coil (90* to any point in the coil wrap). Any given point in the coil is a lever arm, that is twisting the adjacent (90* away in the wrap) part of the bar. All the way through the coil.
Crazy that you know that poster...you're right, the guy knows what he's talking about. That would be a good friend to have.
