Ran into slight problem w/CORSA installation....
Old Nov 12, 2002 | 11:39 PM
SouthernSon's Avatar
SouthernSon
Default Ran into slight problem w/CORSA installation....
First, the exhaust is all that is advertised. I am completely satisfied. However, upon installing the header extensions, I found a difference in length of about a 1/2 inch. Since the center muffler fits flush at equidistance, I proceeded to 'sawzall' a half inch off the longer one. Everything was great until I got to installing the muffler pipes, 'very, very' close to running out of clearance with rear suspension. It seems that instead of one header extension being 1/2" too long, it was the other that was 1/2" too short. So far, though, all seems to be OK. My recommendation is to measure very closely upon installation. :seeya
Old Nov 13, 2002 | 05:19 PM
khornet's Avatar
khornet
From: Phx/but its a dry blast furnace kinda heat AZ
Default Re: Ran into slight problem w/CORSA installation.... (southern_son)
Did you talk to the folks at Corsa before breaking out the sawzall?
You should not have needed ANY modifications to make it fit.
Old Nov 13, 2002 | 05:37 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: Ran into slight problem w/CORSA installation.... (khornet)
I ordered a ZR-1 system and got shipped a LT1 passenger side pipe. They over nighted a new one that fit. No mods should be necessary
Old Nov 13, 2002 | 06:39 PM
tdock's Avatar
tdock
My corsa seemed really short and tight to the rear differential, played with the angle of the cats and that seemed to lengthen it out a little. The cats were RT's so the stock cat brackets had been removed, allowing for some variation on the angle of the cats.
Old Nov 13, 2002 | 07:45 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Mine fit perfectly.
Old Nov 13, 2002 | 07:51 PM
bogus's Avatar
bogus
Default Re: Ran into slight problem w/CORSA installation.... (Mr Mojo)
Mine fit perfectly.
so did mine. but I did have to lower the rear diff spring perch a bit, just to allow for some more exhaust clearance.
Old Nov 14, 2002 | 11:21 AM
C4DC's Avatar
C4DC
St. Jude Donor '06
Mine fit fine as well... :cheers:
Old Nov 14, 2002 | 01:09 PM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Cruise-In VI Veteran
Default Re: Ran into slight problem w/CORSA installation.... (C4DC)
To Ran into slight problem w/CORSA installation....
