Bypass valve upgrade advice
Old Sep 19, 2019 | 01:29 PM
Jkno96's Avatar
Jkno96
1st Gear
Default Bypass valve upgrade advice
Hello- I have the vortech LT1 kit on my 1996. Pretty sure the bypass is leaking off boost after I upgraded the impeller and put on a smaller pulley. Does anyone have some part numbers to replace the bypass valve ? I am still using the 2 bolt valve that came with the kit. Thanks.
Old Sep 20, 2019 | 07:31 AM
LTxDave's Avatar
LTxDave
If you're not positive it's the bypass valve, make sure belt slip is not your issue before you start changing parts.
