Time slip vs Draggy
The phone software may be inexpensive and okay for general purposes but I like the additional things the GTECH does as well. The torque and HP curves are great but the shift light that is "feeling" your engine and tells you when to shift for the optimum times has helped "learn" my Corvettes.
The GTECH is more expensive but for that quality of equipment you will pay more. I ran the Gtech and then made adjustments or repairs and ran it again right away to see if there was any difference. That i how I knew my Cat-back system and a new Hi-Flow catalytic gained me just shy of 14 hp. Even carburetor changes can be tested right away. The most important thing about the GTECH is it needs a precise weight for your Corvette before anything can be measured. I went to the local landfill and got weighed with car empty of junk with 1/2 tank of gasoline. I had to do the same with my C3 to get it's "REAL" weight.
Truck-stop scales are better and more accurate but they charge to weigh your vehicle. Check out the GTECH and see what that baby can do, I suspect you will be impressed! I want the Road racing version so I can practice auto-crossing better.
Best regards,
Chris
Best regards,
Chris
I purchased a used Gtech about 6 months ago. Been playing with it, testing 0-60 mainly..... To be honest, my biggest problem has been finding a piece of road to test on. One that is flat, not too much traffic, and hopefully somewhat cop free!!
Hard to find that in northern Va. at least my part...
The county I live in, is over 400,000 in population....
But I sure am impressed with the accuracy of the dragy.....
Also, IMO if you are pulling 1.99 60ft times on street tires and a manual trans.... well, that is some good driving!!
BTW what was the DA on that run?
The DA was in the 2150' - 2650' range. The dragy app puts it at 2641' and the DragTimes.com calculator puts it at 2141' for that run. I don't really know what to believe as some of the guys at the track were trying to tell me it was in the mid 70°s but I don't think it got to that temp until ~6am. The run posted above was at midnight. I ran 12.0 - 12.1 all night at 120.xx w/ ~2.0-2.1 60' times and I starting running at about 7 pm and I made my last run at midnight. I tend to believe the DA was pretty steady like the dragy app reported all night. Between ~2641'-2780'.
I live in Fairfax County and you are right there are "limited" places you can do it. I go to shopping mall parking lots or school parking lots for 0-60 runs. I find that going from 40-60 gives me a good indication of whether I helped the car or made it worse. Even a good 40-60 run might show important information regarding the engine. My C3 is a big block and tire spin is a HUGE issue so for me I like rolling starts or gentle starts to gets a good idea of how the engine is running.
How did you get your cars weight? Did you get it weighed or are you using the GM information? My C4 weighed less than GM suggested a Coupe would weigh and so did my C3 convertible. I weighed my car at the Ox Road landfill as they have a fairly accurate scale. I have seen far more accurate weight measurements from truck stops but they cost money.
I have done some runs in large open parking areas where there is no chance of hurting someone. The old Kena Temple in Fairfax had a huge parking lot and was perfect as it was empty several days a week. A good part of the Fairfax County Police department knows about my Corvette and have been very friendly. The local police might help identify a place you can do some runs like that, as long as you don't go too fast or get reckless. Sometimes they are really helpful. The only time I had issues with our local law enforcement was passing their station outrunning a Kawasaki 600 at triple digits, not a good move or even a bright one. One of the officers showed up at my house and suggested I be a "bit more careful".
Three officers looked at my engine one day and they were all telling me how their cars were no match for this C3 427 powered Corvette, I smiled and suggested that I was smart enough to know that you can't outrun a radio.
Good luck,
Chris
P.S. Whatever you do, don't do any timing with other cars around! Here in Virginia they confiscate cars caught drag racing on public roads. They are very serious about it so every time an Asian car pulls up and revs their engine I just laugh at them.
I've pulled a 1.9 60' time, but not here in UT. I had to GO DOWN TO VEGAS to have enough TOWAK, do it.
