Drooping headlamp door...HELP!
Old Nov 13, 2002 | 09:56 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Drooping headlamp door...HELP!
Can anyone recommend a fix for a drooping headlamp door on my '92 Coupe? I've played around with the rubber stop located at the top (underside) of the headlamp and tightened down the black **** on top of the motor, but the unit still seems to have some play in it when I press down on it from above with my hand.
This problem is particularly noticeable when I encounter bumpy roads, but the headlamp door immediately aligns itself in the correct position when I flip the lamps up, then close them again. What gives? Anyone else ever encounter this problem? :confused:
Old Nov 13, 2002 | 10:19 AM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Default Re: Drooping headlamp door...HELP! (onedef92)
Worn gears.... :)
Old Nov 13, 2002 | 10:46 AM
PTCvette's Avatar
PTCvette
Default Re: Drooping headlamp door...HELP! (Mervz)
Exactly right... Drooping headlight = worn gears, or else that goop that they seal them with! Mine had the droop going really bad, and I got those nylon bushings from Corvette Country here in Fayetteville. Armed with those and a few hours to kill, my headlights were good as new!
Jeff
Old Nov 13, 2002 | 10:56 AM
onedef92's Avatar
onedef92
Default Re: Drooping headlamp door...HELP! (PTCvette)
Can someone e-mail me instructions on how to replace worn headlamp gears and bushings? I can get the improved bronze ones easily enough from MAD at a decent price. Thanks!
[Modified by onedef92, 10:56 AM 11/13/2002]
Old Nov 13, 2002 | 12:02 PM
Steel Blue 91's Avatar
Steel Blue 91
Go here. http://www.madvet.com/pdf/601703.pdf
It's the instruction sheet that you get when you order the kit.
Old Nov 13, 2002 | 12:20 PM
onedef92's Avatar
onedef92
Default Re: Drooping headlamp door...HELP! (Steel Blue 91)
Thanks, Steel Blue 92 et al. You guys are the greatest! :cheers:
To Drooping headlamp door...HELP!
