86 c4 fuel pressure issue
Old Oct 7, 2019 | 01:29 PM
Mickey Repac's Avatar
Mickey Repac
5th Gear
Default 86 c4 fuel pressure issue
Hello,
I have 86 C4 Corvette and have issue with fuel pressure. Pressure will stay at 25 psi and when i turn the car off goes to 10 psi. It take at least 20 turns to started cold and after that it runs but has no power.
Help please
Old Oct 7, 2019 | 02:01 PM
aklim's Avatar
aklim
Something might be leaking. Try crimping off the return line at the tank and have someone turn the key and see what happens.
Old Oct 7, 2019 | 02:34 PM
Mickey Repac
5th Gear
I have tried it with engine running and didn't see any difference. I have replaced fuel pump and filter.
Old Oct 7, 2019 | 02:35 PM
aklim's Avatar
aklim
So you turn the key to run and have the return line crimpped off? You can't get 40 plus psi?
Old Oct 7, 2019 | 03:19 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
X2^^^
Bad pump or a leak somewhere.
Old Oct 7, 2019 | 03:57 PM
Mickey Repac
5th Gear
I have replaced 2 pumps in past month, i did buy one of the cheaper ones. I did take pulsator out, You think that would make it not build pressure?
Old Oct 7, 2019 | 04:06 PM
aklim's Avatar
aklim
I doubt it. Are you sure it is not building pressure but the regulator is letting it out?
Old Oct 7, 2019 | 08:18 PM
383vett's Avatar
383vett
Sounds like the regulator is bad. If you have gone through 2 fuel pumps and still have the same problem not building up pressure, change the regulator.
Old Oct 7, 2019 | 09:35 PM
aklim's Avatar
aklim
Have you tried crimping off the return line to the tank to see if it builds up pressure to 42 psi?
Old Oct 11, 2019 | 11:41 AM
Mickey Repac
5th Gear
I have tried pinching return line and pressure stays the same. I have tried new pump and i am still getting 25psi. I am thinking that the gage is not reading properly.
Old Oct 11, 2019 | 04:35 PM
vader86's Avatar
vader86
Try another gauge, otherwise if you've pinched off the line as recommended and still get that low a pressure, the FPR needs replacing.
Old Oct 11, 2019 | 06:29 PM
aklim's Avatar
aklim
If he pinches off the return line, wouldn't that ensure full pressure, regulator functioning or not?
Old Oct 11, 2019 | 08:07 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That's right. If pinching the return line results in NO CHANGE to fuel pressure, then the regulator is not likely the problem.
Old Oct 14, 2019 | 12:49 PM
Mickey Repac
5th Gear
Ok, got it fixed. Installed new stronger pump and replaced wires on the sending unit.
To 86 c4 fuel pressure issue
