Charging problems
Old Oct 8, 2019 | 09:51 AM
X xSuperx's Avatar
X xSuperx
1st Gear
Default Charging problems
So i am having problems with my c4 charging i charge my battery and it reads 12.9 when i start it it reads 12.6 and slowly starts dropping and then dies i have a good battery and alternator and have no shorts and spliced a new battery terminal in place of the corroded one. It helps but doesn't fix the problem
Old Oct 8, 2019 | 09:24 PM
hcbph's Avatar
hcbph
Your dash gauge could be bad so be aware of that p ossibility. It's possible it could be the charging wire (was on mine). Take a heavy wire from the lug on the alternator to the positive battery post and see if that makes a difference in your charging and voltage readings. Just be careful of the old wire, it should be hot on both ends.
Old Oct 8, 2019 | 10:57 PM
jv9999's Avatar
jv9999
That would work, or you could measure the voltage between the alternator output and the battery + terminal. It should be <.2V. Chances are your alternator is bad, I'd have it tested at most any auto parts store.
To Charging problems
