C4 Corvette Start and Idle issues
Old Oct 9, 2019 | 04:37 PM
Aidan652's Avatar
Aidan652
Default C4 Corvette Start and Idle issues
Hi guys! Im pretty new to the corvette community and im just starting to work on cars as a hobby while I am still in school. I recently started having problems with my car starting and sometimes it idles rough. Im going to list just a few of the problems that started occurring. Some might be unrelated but oh well.
-Car used to start right away. Now it has to turn over quite a few time to start up. Not consistent
-Smoke comes out the back. The longer the startup takes, the bigger the smoke. Only smokes when started
-TPS sensor light keeps coming on. Not sure why. Replaced it twice now. Sometimes stays off, sometimes turns on after the car starts rough.
-Idles rough. Kinda jerks a little. Not too bad
-When the engine is revved it sounds like an air hose is leaking?
I have swapped the fuel filter so I know that its clean.
BTW it is a 1987 C4 Corvette
Really hope you guys can help me out. Thanks!
Old Oct 9, 2019 | 05:02 PM
FX VETTE's Avatar
FX VETTE
Welcome to the CF!
Old Oct 9, 2019 | 05:39 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Welcome to Corvette Forum! Your questions will be moved to the C4 Tech Forum. Good luck!
Old Oct 9, 2019 | 05:58 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Welcome to the forums. You'll learn a lot about cars, owning an older C4.
What color smoke?
You mean the Check Engine Light?
Have you checked for for vacuum leaks? Or is it possible the exhaust is plugged? How is the power once your on the road with it?
Old Oct 9, 2019 | 06:42 PM
Aidan652's Avatar
Aidan652
What color smoke?
I believe that the color is white/gray. Smells like gas but only smokes we the car starts up. After 5 seconds it stops. Yes the check engine light comes on sometimes with the TPS but thats not the main problem. Havent been able to check for vacuum leaks. But I think i can hear one when it is revved quickly. I do not believe the exhaust is plugged. The power is great on the road. Idles a bit funny when at a stop light but always stays running. No performance issues when driving it on the road.
Old Oct 9, 2019 | 06:49 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
If the Check engine light comes on and is TPS related this is a problem, if TPS is not correct how can the system control the fuel needed? You need to fix 1 issue at a time.
Old Oct 9, 2019 | 08:11 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That you've replaced the TPS doesn't guarantee that you fixed it; there may be a harness/connector issue causing the actual problem. I'd look into that further.
I'd check for vacuum leaks
Good performance is a strong indicator that the exhaust is NOT plugged. Good news there.
You could put a fuel pressure gauge on it and see...pressure...but also if there is leak down after it's shut off. It's possible a leaking injector could be flooding it, making it hard to start.
Old Oct 9, 2019 | 09:36 PM
Aidan652's Avatar
Aidan652
The light only comes on sometimes. Its pretty rare but random it will. But it always has a hard time starting. It almost seems that if i leave it sit for a few days its starts up faster?
Aidan652's Avatar
Aidan652
Ok i will look into getting a fuel pressure gauge. Thank you
Old Oct 9, 2019 | 10:51 PM
aklim's Avatar
aklim
And a Factory Shop Manual, aka FSM not the Haynes or Chilton toilet paper and a real scanner, not a code reader aka paperclip
Old Oct 14, 2019 | 06:54 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
What voltage did you set the TPS to?
Have you checked the timing?
Old Oct 14, 2019 | 10:21 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Yes, the check engine light comes on sometimes with the TPS.
TPS sensor light? Is there such a thing in an '87?
Old Oct 15, 2019 | 08:02 AM
kael's Avatar
kael
There's not a specific light, but there are codes 21 and 22:
21: Voltage at TPS too high
22: Voltage at TPS too low
Old Oct 15, 2019 | 09:09 AM
aklim's Avatar
aklim
If you are determined to kep the car, get a scanner so we can see exactly what the ECM sees. Much easier for someone to read. Just because the output from the sensor is correct does not mean the ECM sees it that was because the wire might be broken. Ask me how I know.
Old Oct 15, 2019 | 09:12 AM
RalfKramden's Avatar
RalfKramden
Seems like you may have a leaking injector(s) since you say it starts better after it sits a day or so as opposed to jumping in after a few hours. That would account for the hard start/smoke. It's unburned fuel (causing the smoke) and fouling the plug(s) causing the hard start. When you put the fuel pressure gauge on, start the car. Check the pressure then shut down and see if it bleeds off pressure in a short period of time. That would indicate if you have leaking injectors. To search out a vacuum leak, get a can of brake cleaner and with the engine running (this is a quick and dirty test), spray the brake cleaner around where you think you hear the hissing. If the engine revs up/smooths out, you've found the general area of the leak. Good luck!
Old Oct 15, 2019 | 09:14 AM
aklim's Avatar
aklim
If the injectors are Multecs, I'd dump the anywhere since the new injection mean that I can fuel anywhere instead of being limited to a few.
Old Oct 15, 2019 | 09:47 AM
aklim's Avatar
aklim
I don't know if that does indicate a failed set of injectors. I would not start the car. I'd prefer to turn the key to run, see what the pressure goes to and see if it holds. If not, go find the return line at the tank, crimp it off and repeat test. If it holds, regulator would be the first BUT NOT only suspect. If it doesn't, you may have to repeat test AND this time crimp off the feed line after the prime or trigger the pump and crimp off the feed line. So if it spikes up and you crimp off both ends, it leaves the injectors or a ruptured diaphragm.
To C4 Corvette Start and Idle issues
Old Oct 15, 2019 | 11:04 AM
vader86's Avatar
vader86
So its an outlay but you need the Helm Manual. Helminc.com.
You need a fuel pressure gauge, it hooks up at the fuel rail. It should run steady at about 43-45psi, watch and note how long it takes for the pressure to drop when you turn the car off.
You need a scanner, Actron makes one that you can get at Autozone, for OBD-1 cars. You can buy the OBD-II and theres an adapter for OBD-1. This will tell you what the ECM sees as the TPS voltage. It should be 0.54 V at idle. IAC counts are another thing the scanner will tell you, if they are 100+, theres probably a problem there. If the idle is hunting or struggling, they'll be all over the place, most likely.
Look through all the hoses and see if you can find the vac leak. If you find one, unplug the battery and clear the code, and see if it runs right after a restart.
Lots of things to check, do one at a time.
Old Oct 15, 2019 | 11:05 AM
Aidan652's Avatar
Aidan652
yes. It usually says code 22 when it does show up
Old Oct 15, 2019 | 11:18 AM
aklim's Avatar
aklim
If the IAC is at 100+, doesn't that mean the ECM program is commanding the IAC to open up for more air? I would think that if the adjustment screw out as you can do and it is still 0, there is an air leak? Or did I get it reversed? The usual way I have set the IAC is to get the motor to closed loop, turn everything off but the motor and adjust the screw till I get about 20 to 30 counts. The last few times I have got 0 with the screw all the way out, there was a leak either by a vacuum line or gasket failure.
I have always done it once the engine reaches closed loop. Never tried it with the engine cold. Know of any difference?
