Confused
Old Oct 20, 2019 | 01:55 PM
Brandonvette's Avatar
Brandonvette
Default Confused
new here and I've read for this question but confused about the answer . 87 Corvette with aluminum heads. ALL MY INTAKE BOLTS ARE AT 72 DEGREE ANGLE . is this the stock heads or do I have a frankinstin motor? O and the intake part number is 10066013. Thanks
And no I can't see any casting numbers on the heads or block or I would of just goggled the numbers
Old Oct 23, 2019 | 05:25 PM
Tunedport90's Avatar
Tunedport90
You should have 128 heads. I think there 90 degree bolt holes in the middle.
Old Oct 23, 2019 | 06:39 PM
Brandonvette
Is it possible to have lt1 heads? I'm having a 383 stocker being built for me out of state and I told them it was a 87 Vette and he asked if it had center bolt valve covers and yes then they have the right heads for me to use when they build it just need to make sure I don't get the wrong heads for my intake
Old Oct 23, 2019 | 06:54 PM
vader86's Avatar
vader86
No you wouldn't have LT1 heads on that car, LT1 is reverse cooled and the coolant passages won't line up.
Look under the valve covers to get the casting number.
Old Oct 23, 2019 | 07:03 PM
Brandonvette
If it wasn't such a pain to get the covers off I would the motor not pulled yet waiting for the new motor to come
Is there numbers in the back of the head I might be able to read with a light and a mirror?
To Confused
