84 Dash Cluster, solution
Old Oct 21, 2019 | 09:26 AM
knightp25's Avatar
knightp25
Default 84 Dash Cluster, solution
My 84 Dash Cluster, when i purchased the car (about a month ago) i never saw the dash cluster work
Well..... yesterday while in the car, the sun came out, and i put my sunglasses on, and sure enough, i could see the lights on the dash.
I was so thrilled, that it actually worked, and i dont have to send in for repair. i ordered the polarized kit, cant wait for it to come in.
So until then, guess i'll have to wear polarized sunglasses to see it lol
Old Oct 27, 2019 | 02:51 PM
65mopar's Avatar
65mopar
Default Dash cluster
Glad your cluster problems are easily fixed.
I would caution you to be sure to get the little rubber alignment pieces are in right as I had one that held my one of my lenses up and when I re-installed the power module it cracked and ruined the oil, water, charging and gas gauge read out.
I then opted for the Intelletronix digital kit.
It's not plug and play so you have to wire it yourself and I am having trouble getting the right info to wire my speedometer right and their support sucks.
Old Oct 27, 2019 | 06:28 PM
hcbph's Avatar
hcbph
Are the backlights on in the cluster? Are the turn signal lights on? There is a known condition with the Atari clusters where the ground goes out between the 2 boards in the cluster and though the cluster is working, it's unreadable. That's what happened to mine and I sent it to Batee to have it repaired. Bryan changed out the connector between the two boards and replaced all the bulbs with Xenon bulbs. He did a great job at a reasonable price and it's been working fine ever since.
For more info, check out Batee.com as there's a wealth of info on his website.
Old Oct 28, 2019 | 08:18 PM
Benny42's Avatar
Benny42
I used the lenses from 3-D glasses from a trip to the movies for a while till my kit came in and i had an open saturday to redo the film. It ain't stupid if it works.
To 84 Dash Cluster, solution
