Replacing ragjoint in steering shaft
Old Oct 25, 2019 | 11:48 PM
gdl2165's Avatar
gdl2165
Default Replacing ragjoint in steering shaft
In all the years I've been on this forum, twice now I've come across someone in the For Sale section asking about buying a new ragjoint for the steering shaft. GM used to sell the entire shaft for over $500, I don't know if it's even still available or not. When I had this issue with mine a few years ago I came across a thread on the CorvetteActionCenter site discussing this and there was one member there who posted some instructions on how to inexpensively replace just the ragjoint in your existing shaft. I searched this forum and didn't find anything like this so I just had a thought that maybe I should make this thread and post those instructions for posterity,. This was originally posted by user 'lone73' on that site. I used these instructions, purchasing the ragjoint at my local Napa auto parts. I don't have a part number, what I ended up doing was taking my original one to the store and asked them to match it with something they had on-hand. It's worked out great.
This is the original thread from the other site:
https://www.corvetteactioncenter.com...lay-wheel.html
And below is the text from the post there that explains how to do it:
I got the rag joint in the "Help!" section of the local parts store. Those are typically cheap parts but it was all I could find locally.
To get to the rag joint, first disconnect the negative battery cable so you don't set off the air bag. The instructions in the manual say to be careful not to compress the output shaft of the column (push it toward the firewall) or you could damage part of the air bag system.
I removed the bolts holding the A/C compressor and moved it out of the way, then did the same for the ASR box. There is a plastic cover on the lower end of the shaft assembly under the hood that is held on by a hose clamp at its lower end. Loosen that, then the cover also has a snap together connector on the bottom side that you'll have to reach. Then the fun part, trying to get the cover out without breaking it. I broke mine and absolutely could not get it back in there at reassembly. I left it off the car.
Once you get this far you can unbolt the lower u-joint assembly from the input shaft on the rack, one bolt. then do the same for the upper end on the output of the steering column shaft, as noted above, be careful not to compress the steering column shaft. Also lock the wheel and don't move the front tires so the orientation of tire direction to steering wheel is not lost.
Once the bolt on the upper end is loose you can slide the shaft assembly off the column output by pushing it to the side, then slide the shaft back and off the rack input shaft. The shaft assembly is now free from the car and you can drill out the pins holding the rag joint to the lower u-joint and replace it. They give you bolts to use in the kit in place of the pins.
When you're done I think you'll notice a huge difference in the steering.
good luck
One other thing I forgot to include above. I removed the center section of the inner fender well right above the A-arm...
And a reply from another user there, 'sanjirelli', with some info about what parts to buy:
I ended up combining parts from 3 separate cheapo kits (total cost $25); 1 kit for the GM sized rag joint and 2 kits for Ford bolts and sleeve nuts (each kit only came w/ 1 ea of the items).
