Coilover setup?
I have a Carrera kit on my C4 that bolts to the stock shock mounts.
However, getting access to scales to corner weight the car is what you may
need to consider. Unless you equal the diagnial weights the car will never handle right. Search this site, someone wrote a very detailed
procedure for removing springs safely using a floor jack. Then see if you can find a road or roundy-round racer in your area who will give you some
"scale" time. If you can't get access to scales I would pass on the idea
or plan on getting them professionally installed by a tuner shop.
