Good Evening, does anybody have or know factory ride heights front and rear from center of wheel opening to the ground and also pinch weld to ground front and rear rocker panels ? Any help would be appreciated !
All the measurements are in the FSM for your year, List your year maybe someone will be able to post a pic from the page showing were to measure and measurements.
1995 corvette coupe FSM ?
There's lots of information in FSM. The pages you need are in section 3 steering, suspension, tires and wheels. Trim height 93 lists 4 models coupes should be approx 192mm. Measured at front edge of door and about 4 inches forward of rear edge of door. Measure from flat part of rocker panel to ground.
datum line is an imaginary line that locates points on underbody or frame. It's become an obsolete process with the advent of laser measuring systems.
