Got Keyless Entry installed but........
Old Nov 14, 2002 | 09:50 PM
Dudeurgettnavette's Avatar
Dudeurgettnavette
Default Got Keyless Entry installed but........
Got Keyless Entry installed but every time I unlock it from the remote the theft deterrent system goes off. Only happends when I lock the car up and close it up. Is there a way around it, or am I gunna have to disable the alarm? Don't the 93's and up have keyless entry? :confused:
Old Nov 15, 2002 | 01:10 AM
JasonL's Avatar
JasonL
Default Re: Got Keyless Entry installed but........ (Dudeurgettnavette)
Did someone else do the install? It sounds like they did not add a relay to turn off the alarm when you hit unlock on the remote.
On my '96, the factory alarm will only arm if you lock the doors before closing. If you close the doors before locking, the alarm won't arm (it assumes a person is inside the car). You might try closing the doors, *then* hitting lock on your remote...that might prevent arming the alarm.
Well, actually the PKE/alarm operation is slightly more complicated than what I described, but that's the general idea.
Old Nov 15, 2002 | 09:14 AM
Steel Blue 91's Avatar
Steel Blue 91
I have considered adding this to my 91. What brand and model did you install?
Old Nov 15, 2002 | 10:38 AM
fullboogie
Default Re: Got Keyless Entry installed but........ (Steel Blue 91)
I have been through this problem with my factory alarm interfering with my aftermarket alarm, and here's what I've found:
As stated above, if you manually lock the doors before arming your aftermarket alarm, the factory alarm is engaged and will go off when you disarm the aftermarket alarm. I've studied the wiring diagrams, and have found which wire to cut going to the CCM to disable the factory alarm. Actually, it's the wire that tells the CCM to enable the factory alarm when the doors are manually locked.
Problem is, I can't get to the wire. I've taken out the radio to get to the CCM, but there's some metal bracing in the way. I can SEE the wire I want to cut, and I could probably reach it with some snips, but I won't be able to reconnect it if I need to.
I've had many discussions with others on the Forum about this, and it appears that the only way to fix this problem is to somehow keep the CCM from enabling the factory alarm. And our conclusion is that this particular circuit must be disabled. If you look in your service manual and read all the wiring diagrams, there will be a circuit that is labeled something like "enable UTD", which stands for Universal Theft Deterrent. That's the one that has to be cut.
Let's keep everyone posted if someone is able to fix this.
Old Nov 15, 2002 | 04:22 PM
Dudeurgettnavette
Default Re: Got Keyless Entry installed but........ (JasonL)
Someone else did the installation, I got it done at Alta Mere. When I close the doors then hit the lock the alarm doesnt go off when i go to open it! :D
Thanks for the info :cheers:
To Got Keyless Entry installed but........
