I have the normal tires on my 1995 convertible. I will need new tires in the spring . my question is , can I switch to run flats without having the low tire pressure sensor? I could then save some weight by getting rid of the spare tire .
I wouldn't use run flats they have very stiff sidewalls and will effect ride quality. They are also more difficult to change. Some shops won't cover rim damage during change over. Just carry the jack and a can of " fix a flat" if you want to lose the spare snd carrier. Tire plug kit and a 12v compressor would be better, than fix a flat. Years ago Uniroyal made a self sealing tire. You would think someone would make and sell that type of tire now.
Driving a C4 with R-F tires on it is like riding in a freight train car.... Theyre noisy and not forgiving.... If you like to push the car into turns and have some fun, these tires are not for you... There is a night and day difference between R-F and good regular tires. Dont do it man!!
the sensor requirement is pretty much for old grandma who would not recognize a flat tire.
all of us are in tune enough with our rides to notice something different in ‘performance, handling, ride quality or ‘noise’ when a tire goes flat.
when i drove a flat goodyear runflat tire (as part of a demo), i noticed a big difference in ‘noise’.
it sounded flat, didnt corner well in one direction (i think the lf tire was the one they flattened and in right turns it wanted to understeer bad).
i also wouldnt do run flats bc they add unsprung weight. The worst kind of weight. Youll need to give more throttle coming off the clutch (if its a stick).
the old run flats also didnt last long bc all road forces went into the tread (vs the sidewall which usually absorbs part of the road shock).
bridgestone makes a ‘driveguard’ runflat that mitigates a lot of these disadvantages. But its not an ultra high performance tire. Its meAnt for more mom in the minivan and I doubt it comes in our size.
Keep in mind that Fix A Flat type sealers only work on small nail/screw punctures, usually not on slices larger than a 1/2", and not at all on a large side wall damage. If you're only driving locally it's an option to carry this with no spare, but better have the spare for long trips. However, who cares about a little weight unless you're racing your Vette?
This is wrong. Unless you are cornering, there is no difference if a run flat has no air vs 30psi. I was on a freeway with my C7Z06 Michelin MPSSZP when the low pressure light went on. The sun was behind me coming into the driver's window lighting up the dash. I must have been driving for a few miles at 70 mph. The inside of the tire was toast but at least I made it off the bridge. There was absolutely no change in ride or noise when the tire lost air. I could have driven 70 mph for an hour until the tire blew if I didn't have the dash warning.
umm there most certainly was in my situation.
in your situation was tire completely flat?
Im betting it still had 15 psi in it or so. Maybe by the time you pulled over it was 0 by the time you checked it.
i cant speak for the vette sizes but the p205/65r15 tire that was on the car (nissan maxima) I drove - it was very obvious at 0 psi.
Tire had lost all it's air due to a slash from something on the road. Zero pressure. Running on a run flat at 70 mph for a few miles will toast the tire.
