Key Fob repair
Old Nov 3, 2019 | 12:43 PM
dskopp's Avatar
dskopp
Cruising
Default Key Fob repair
1998 Corvette . One key Fob is not working, battery is ok!! What next?
Old Nov 3, 2019 | 03:17 PM
CorvetteRules's Avatar
CorvetteRules
Open and clean all contacts.
Old Nov 4, 2019 | 03:35 PM
markKlein's Avatar
markKlein
Post in C5 section
Old Nov 5, 2019 | 05:04 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
On my '99 I found that the early (97-00) key fobs fail frequently. The 97-99 fobs have the passive option and are expensive if you can find them.
In the C5 section there are some threads you can search for on a common problem that re-soldering a post can fix. However that did not work on mine.
I went with converting it from the early to the late C5 system. I bought two new fobs, the receiver and tire sensors. The tire sensors cost less for the late than the early. For me it was less expensive to swap everything to the late system than just buying the tire sensors and fobs for the early system. Since I did that 5 or 6 years ago, they have worked perfectly.
I don't know if that is an option you may like or not, but it worked for me and is something to consider.
Good luck.
Old Nov 6, 2019 | 11:00 PM
dskopp's Avatar
dskopp
Cruising
Good luck.
I have a 1998 with two Fobs Early so everything is more ex[ensive. Going to replace one of the fobs
Old Nov 17, 2019 | 04:08 PM
OregonDan's Avatar
OregonDan
I might have a fob for yo if you're still looking! PM me.
Old Nov 17, 2019 | 07:16 PM
dskopp's Avatar
dskopp
Cruising
Default 1998 fob
Not sure how to IM you. Please send me an email to SDa4651343@aol.com
To Key Fob repair
