Parasitic Draw
Does anyone have a method of figuring out how to do that?
Your parasitic draw should be ~35 mA is everything is working properly.
If you have a good multi meter you could install that between the battery Ground and the battery ground cable and use it as a ammeter. A lot of meters have a limit of 10 to 20 amps before they blow a fuse.
Either way you do it Tom400CFI is correct about unplugging each item, it is the easiest way to find the load. You could look in the FSM and find out what is on that particular circuit that could be drawing that much power. That would make the search a little easier.
Best regards,
Chris
Then disconnect each item/cicuit on that fuse. Shouldn't take long, I don't think. You got:
DIC
Hood lights,
Horn relay
Courtesy lights
Door lights
Dome light timer
spare tire light
Cargo lights
vanity lights
console light
Cig lighter
Radio clock
Dinger/chime
That's quite a few things on one fuse, but you could get through it fairly quickly I'd think. I wonder if one of your lights is staying on; the console lights? Or one of the Vanity lights maybe?
I'd suggest starting with the cig lighter.
Power antenna
Power door locks
Bose amp relay (possible hum from speakers with radio off)
Are all of these items working properly? Something is stuck on, and probably not working as it should. A short circuit would draw more than 4.7 Amps, and would blow the CTSY/CLK fuse.
The normal current thru the interior lamp timer of my '84 is 3.15 A, with the courtesy lamps ON. My normal residual current drain is 0.013 A (13 mA).
Good catches though. I think the door locks would draw way more than 4.7A (but haven't tested them). Pwr Antenna and Bose amps are a possibility though. I'm just barely above neophyte when it comes to the electrical system but I'm going to investigate the amp draw further.
Second: Check your power seat tracks, they can pull a bunch of current if the limit switch is off or broken. Disconnect them and check your current loss for any changes. The same for power mirrors....
Have you checked out the overall system yet? The fuses in your Corvette have Fusible links to be a last line of defense before the battery. I have found lots of corrosion at the connection post where the battery cable feeds the 12 Vdc power into the fusible links. On my 1988 C4 it is behind the battery under the side cover and is easily identifiable by the fairly large red wire coming directly from the battery Positive connection. I do not know where or if the 1984 C4's had this post anywhere near where mine was.
Measure the battery voltage with nothing "on" but connected to the car. The measure the voltage at your fuse box, they should be very close or the same. If not you have a problem before the fuse box then I would find the little connection post and make sure it is free of any corrosion. On my car the post were really badly corroded and caused a serious voltage drop (~2 Vdc) at the fuse box. After cleaning the terminals the voltage drop disappeared. I now had power at the fuse panel but not past that point.
Sometimes the fuses get a layer of corrosion on them that you can't see, On my car the fuses were all visually "Good" but there was nothing flowing through them. After cleaning the fuse block with a points file I installed new fuses and the power went where it was supposed too inside the car. Never assume a fuse is "Good" until you have tested it. My fuses looked brand new but had a layer of corrosion that impeded the flow of electricity. Cheap fuses were made of aluminum and they had a fine layer of white powder on their surface. I checked where the fuse is held and there was power there, it just stopped at the fuses which all looked perfect.
Check the battery voltage and then leaving the red lead on the battery Positive put the black lead on the engine block and again measure the voltage. These should also be the same. The engine needs a good solid ground to work properly. On my 1988 C4 there was a broken ground strap near my mufflers on the drivers side. After fixing it the antenna started working perfectly.
Power door locks can be disabled by unhooking the power wires. Frequently on these older Corvettes the door and lock mechanisms get frozen up with the old grease they applied at the factory. I opened up my door panels and spent hours cleaning the old stuff off and freeing up the parts. Afterwards you barely touched the switch and they would lock or unlock immediately. This is a good project if you have a garage or someplace out of the weather where you can clean the insides of the door panels. The old grease is like frozen solid and sometimes has to be chipped off.
I still stand by the tool from HF as it would make it easier to do for a non-electrical person. I would also check the Fusible links wherever they were installed on the 1984 Model Corvette. It sounds like your circuits are not getting any power so check your fuses as well.
You may not be an electrically oriented person but by the time we are done getting your car right again you will certainly know more then! This site has a lot of 1984 experts like Hot Rod Roy and Tom400CFI, these guys are still teaching me the differences in the 1984 Model over the later C4's. The experiences that you are tapped into here at the Corvette Forum is pretty amazing. There is a lot of knowledge and experience here to help others with the same passion for the Corvette!
Best regards,
Chris
P.S. Use the FSM electrical manual as it shows each fusible link and where it goes in your car. It is possible top have a bad fusible link, using pins on either side of a single fusible link and test their continuity. ANY Holes made in wires insulation should be sealed up immediately. I use electrical tape but a dab of silicone would do just fine to seal it up.
P.P.S. Check for wires that might have become so hot that their insulation is falling off. It is common as these Corvettes are know to run a bit hotter than normal cars. Check everywhere near the engine and behind it.
Best regards,
Chris
Is your antenna motor totally disconnected? If there's any question about that, remove the antenna relay, which is located under the plastic trim panel to the left of your rear hatch latch. That's a more logical source of your problem. The motor current IS supplied by the CTSY/CLK fuse.
The fusible links in the '84 are located at the battery cable post of the starter solenoid.
Two hours later, down to .21 amps
On the interior light relay, everything I've read says if you leave your doors open with the lights on, it will burn out the relay. I know there are relays available that don't have the delay timer in them, whether they burn out under the same conditions I don't know. Another I've read is if you pull the relay and connect the white wires together the interior lights will go on and off when the doors are opened and closed.
Just some thoughts.
Because I was concerned about running the battery dead I put a negative battery disconnect on it which I would throw every time I parked it. After running the test a number of times over a few weeks I never saw evidence of a parasitic drain so I stopped looking for it but I often wonder if I have an intermittent fault though so far there's no evidence of it. With all the electrical/electronic BS on the C4s it's a wonder we can keep them running.
