After market distibutor
Old Nov 6, 2019 | 10:56 AM
Marcus123's Avatar
Marcus123
Default After market distibutor
Can someone link me to a quality distributor that plug and plays into my 1991 Corvette. All i can find is cheap oem or non computer controlled ones.
Old Nov 6, 2019 | 01:38 PM
braeburn22's Avatar
braeburn22
Have a look for the Davis DUI distributor.
https://performancedistributors.com/...-distributors/
Old Nov 6, 2019 | 03:41 PM
ctmccloskey's Avatar
ctmccloskey
I "Second" the Davis DUI system! I have used their distributors with great success in the past and I am using one of their distributors on my 1988 C4. It was plug and play for my installation.
They make great products and set them up properly for your application. A quality company with a Reputation to maintain will not let you down as often as others.
The modern MSD replacements have been going down hill from what I have heard. A Speed shop owner took my MSD Billet distributor and tried to help get it dialed in for my application using an old SUN brand Distributor machine
Best regards,
Chris
Old Nov 7, 2019 | 06:44 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I would agree with this as well. I am running a Davis DUI small cap remote coil version in my '90 race car. Its been in there for a couple years and does what I ask of it.
Old Nov 7, 2019 | 08:23 AM
C409's Avatar
C409
….. I used the MSD Small Cap HEI EFI distributor for years … never an issue … in fact , its still on the shelf in the event that I decide to go analog on spark distribution again … currently running Holley ECU with coil near plug (LSx style) and FAST dual synch distributor …..
Old Nov 7, 2019 | 08:51 AM
WW7's Avatar
WW7
DUI makes good distributors but they have to be shimmed to be right..When I got mine it was at 0.045 which is way to much , I shimmed it to 0.015 , this is where it's suppose to be..If you buy a DUI distributor be sure to get a shim kit with it....WW.
Old Nov 7, 2019 | 12:26 PM
renegade69's Avatar
renegade69
I have a DUI I'm looking to sell. It was used for 2 years. I had to switch to a small cap HEI when I installed the miniram.
Pm me if your interested.
Matt
Old Nov 7, 2019 | 10:59 PM
jseremba's Avatar
jseremba
C409,
Did the new distributor give you a measurable change i.e. HP, economy, etc. Just wondering. Every time I see something like a different distributor etc. The product literature makes claims. I just wonder if anyone has seen the claims in a measurable parameter.
Thank you
Old Nov 7, 2019 | 11:09 PM
C409's Avatar
C409
Originally Posted by jseremba
C409,
Thank you
….. LOL … I bought the small cap HEI to fit a FIRST Fuel Injection Intake Manifold … I had already installed a healthy cam and had no way to scientifically measure any improvements , changes , etc. that could be attributable to just the distributor … Ask the DUI guys with their 6,000 rpm max engines the same question …..
Old Nov 7, 2019 | 11:36 PM
jseremba's Avatar
jseremba
First of all thank you for the response. And that brings up another question. My car does not see RPM above 5000, mostly just a driver. So when ever I look at high performance modifications I see that they usually are for higher RPMs. I am wondering about modifications that have an effect on a car that is basically a highway driver and once in a great while a day at the track.
Old Nov 8, 2019 | 10:40 PM
aklim's Avatar
aklim
I'd switch to the small cap too if I were you. Just have to change the harness but it isn't that big a deal. In fact, I remember some company offering a PnP solution for reasonable prices.
As to your second question, "How much money you got?" is the question. That determines what you can or cannot do. Before we go there, we need to know what we can spend. That determines if we can do intakes and headers realistically with a tune. If you do the work yourself, under $4500.
Old Nov 9, 2019 | 08:14 AM
C409's Avatar
C409
..... For a basically stock engine , the OEM HEI distributor is more than adequate … save your money … the coil in cap HEI has some performance built right in … most obvious is the direct coil to rotor spark … no coil wires to fail , burn , or that just increase the distance that the current needs to travel to accomplish its task … second , the wider spacing of the spark plug terminals in the large cap HEI help to minimize , if not prevent , spark cross-over from the rotor tip to spark plug terminals … the advantage to most aftermarket distributors is generally their precision … that precision becomes more of a necessity in high revving applications …..
Old Nov 9, 2019 | 11:12 AM
aklim's Avatar
aklim
Wire. 1 wire. Not sure about you but if adequately routed, I haven't had a burn yet on either my F-body or Y-body. By the time 1 wire, any wire, fails, I replace the entire set. Agreed on the distance the current has to travel. Just not sure how far that is and how much it affects things for street running.
Is that a big problem? I misted my small cap distributor several times but I haven't noticed that issue. I suppose with cheap wires it could be.
I think it is also easier to find in that more people seem to make one. Besides DUI, seems like they have more brands for the small cap one and the cap and rotor replacement is easier to get? Or so I casually noticed. Could be wrong.
Old Nov 9, 2019 | 10:43 PM
383vett's Avatar
383vett
I’m using my original 84 distributor with an msd box. Shift at 6700. No problems.
To After market distibutor
