a/c blower
Old Nov 10, 2019 | 08:55 PM
playsdixie's Avatar
playsdixie
Default a/c blower
don't think my blower (85) is blowing as hard as it used to.....high doesn't seem as strong as it was....is there a way to tell if it's the blower motor or the switch....turns on and off ok????? Thanks....Paul
Old Nov 10, 2019 | 11:34 PM
xrav22's Avatar
xrav22
Something you may check is that the the ac box has a gasket around the tubes coming into the engine bay. Also at the heater core firewall the seal need to be present. If not your pressure will be lost in engine bay.
Good Luck
Old Nov 11, 2019 | 06:26 AM
GregMartin's Avatar
GregMartin
When switched to Max the blower relay is energized and switches to bypass the resistor block. Maybe the normally open contact on the blower relay has high resistance due to overheating and age.
ie blower relay may be stuffed.
To a/c blower
