engine rebuild gone wrong
Old Nov 15, 2002 | 03:36 PM
91project's Avatar
91project
Default engine rebuild gone wrong
Need help I rebuilt the engine and now there is a wierd metallic tingy sound comming from the drivers side, it sounds like the valve train but i have had everything checked even went as far as to put a seccond set of new lifters in, no change. the sound is always there but some days it's loud other days not, tried valve adjustment and it gets better but after a day or two it's back, any ideas? :cry
Old Nov 15, 2002 | 03:54 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: engine rebuild gone wrong (91project)
Are you sure there is planty of piston to valve clearance? I know several guys that rebuilt, then had piston to valve clearance problems. One guy found imprints in his pistons where the valves had been hitting. How many miles are on it? If you have a lot, then it is probably something else.
Did you change cranks (stroker)? Tell us about the rebuild...
If you did a stroker, I have heard of some people not nothing their pan and getting some noise from the crank hitting the windage tray or the pan itself.
It is pretty hard to guess what it is based on a tinny sound. I have had a lot of tinny sounds out of my setups in the past. They can be caused by many things.
Old Nov 15, 2002 | 05:38 PM
robert kirk's Avatar
robert kirk
you might take a look at you valvesprings. a weak spring will cause what you describe. good luck robert
Old Nov 15, 2002 | 06:23 PM
91project's Avatar
91project
Default Re: engine rebuild gone wrong (robert kirk)
Thanks for the inputs, no it wasn't a stroker, valve springs are new, valves are new, crank is new. sound seems to be comming from number 5 cylinder all the rest are fine. driving me crazy
Old Nov 15, 2002 | 10:31 PM
No Go's Avatar
No Go
Exhaust leak???
Old Nov 15, 2002 | 10:57 PM
Rynda's Avatar
Rynda
Default Re: engine rebuild gone wrong (No Go)
You didn't get a piston in facing the wrong direction did you? Borrow a bore scope and take a peek through the spark plug hole.
Old Nov 15, 2002 | 11:56 PM
Nathan Plemons's Avatar
Nathan Plemons
A friend of mine had a terrible sound that we couldn't find. It sounded just exactly like a valve ticking because the rocker arm was too loose. We tried everything, lifters, rocker arms, everything.
Finally we just pulled the heads off and found the problem. Somehow his valve seat had come out and it was traveling up and down with the valve! Luckily it was falling back into place each time and thus the piston didn't hit the valve, but that could have easily destroyed that piston had it not fallen into place so perfectly.
Old Nov 16, 2002 | 01:37 AM
TPFKATK's Avatar
TPFKATK
Default Re: engine rebuild gone wrong (Nathan Plemons)
This maybe stating the obvious, but have you used a mechanic's stethascope? These things are awesome, and only $5.
Harold
Old Nov 17, 2002 | 10:16 AM
6spd89's Avatar
6spd89
Totally different engine,but my Briggs and Stratton did the same thing!
I hope its not your seat. The seat was egg shaping the head and causing
NO COMPRESSION on that side of the engine. Check compression first on a couple of cylinders and see what you get.
Matt
Old Nov 17, 2002 | 09:02 PM
91project's Avatar
91project
Default Re: engine rebuild gone wrong (6spd.89)
thanks for the responces guys, after exhausting all possiblities i can think of i'm leaning towards the seat as well.
Old Nov 18, 2002 | 06:54 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
I agree with No Go....did you check for blown gasket in your headers????
Just a simple thought.....If you do finally figure it out please enlighten us..
thanks
:smash:
To engine rebuild gone wrong
