Doug Nash Overdrive Removal
Old Nov 18, 2019 | 01:03 PM
Sean Brian Kirby's Avatar
Sean Brian Kirby
Default Doug Nash Overdrive Removal
Quick question - does the 4-speed have to come out with the overdrive? Dad and I are rebuilding the overdrive. Thanks.
Old Nov 18, 2019 | 04:59 PM
tgurnick's Avatar
tgurnick
Not necessarily but pulling the whole transmission to work on it might be less work than trying to remove/reinstall the OD with the trans in there.
Old Nov 18, 2019 | 06:18 PM
s carter's Avatar
s carter
Once the exhaust and Drive Shaft is out it's only a few more bolts to remove the whole Transmission, also once you've rebuilt the OD with the T-10 pointing down in an old Rim lining up the Reverse gears and Bearings is easier.
Also how old is the clutch it's the perfect time to do it
To Doug Nash Overdrive Removal
