3:45 to 4:11
Old Nov 21, 2019 | 12:48 PM
lt4 coupe's Avatar
lt4 coupe
Default 3:45 to 4:11
Anyone have a direct comparison 1/4 mile, cruise speed, etc. between an M6 car before and after? It seems most people do the ring gear along with lots of other mods which muddies the water a lot.
Old Nov 21, 2019 | 02:46 PM
Kevova's Avatar
Kevova
Wallace Racing although primarily a.Pontiac site has all kinds of calculators
Including 1/4 mile performance and rpm/ speed. There still be variables exact weight, hp, tire diameter and compound. But you should be able to see what to expect.
Old Nov 21, 2019 | 04:36 PM
lt4 coupe's Avatar
lt4 coupe
Oh believe me, ive beat the calculators to death, im hoping for real world actual data... lol
Old Nov 22, 2019 | 10:32 AM
fredk's Avatar
fredk
My stock 93 at that time ran 14.0 Went to 3.54 and ran 13.7.
Old Nov 22, 2019 | 10:41 AM
MatthewMiller's Avatar
MatthewMiller
It's going to depend a lot on your other mods, especially how much power you're making. A stock LT4 on 25.6"-tall tires will top out at 109mph in 3rd gear and 141mph in 4th. Ergo, you'll use three gears in the 1/4-mile. With 4.11s you top out at 118mph in 4th, meaning you'll use most of four gears and put down more average power. You get a lower ET and higher trap speed, assuming you're good at shifting quickly. My car has a lot more power than stock, so I'd probably 3.73s for a top speed in 4th of 130mph (it won't hit the traps at 130, but I also probably would be shifting below redline anyway).
Old Nov 22, 2019 | 12:52 PM
lt4 coupe's Avatar
lt4 coupe
auto car?
Old Nov 22, 2019 | 12:58 PM
lt4 coupe's Avatar
lt4 coupe
My car is currently 385hp 382tq at the wheels with Nitto 305/35-19 NT05R drag radials.
With the super light aluminum flywheel and balancer, it doesn't like to be lugged. I think 4.11s would really help driveability and since it's M6, it has double overdrive anyways so it's not like I'll be tacking out on the freeway...
Old Nov 22, 2019 | 01:46 PM
93 ragtop's Avatar
93 ragtop
Mine is a automatic, and has been in various stages of mods. So numbers from mine would not mean much.
That being said, IMO there are few mods to be done that will equal the feel of a gear change. Going from 3.45 to 4.10's in a stick car will make it feel a lot stronger, at least on the street.
I have had 2.59, 3.54, 3.73, and 4.09. Currently have the 3.73 which is about right with the 26in tires. and a automatic, but I liked the 4.09 better.
If I had a stick LT1-4 the first mod I would do would be 4.10 gears!!!
Old Nov 22, 2019 | 01:57 PM
lt4 coupe's Avatar
lt4 coupe
Yeah I would have done it already if I didnt have to rebuild the motor. Since you have to basically take the whole back half of the car apart!
Old Nov 22, 2019 | 03:48 PM
STEVEN13's Avatar
STEVEN13
My 1992 with headers, 1.6 rockers, tune, (289WHP) stock DM FW on road race tires went 13.02 at 106.65 MPH. With 4.11 gears (solid 9" axle) Aluminium FW and drag radials (315s x 35 17) same engine went a best of 12.84 at 108.54. IMHO it drove better with the heavy flywheel. If I still had the 6 speed (now 4L80) I would have put a heavier flywheel back in it.
Steve
Old Nov 22, 2019 | 03:54 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
http://www.zr1specialist.com/HAT%20W...ucts/gears.htm
http://www.zr1specialist.com/HAT%20W...io%20chart.jpg
Old Nov 22, 2019 | 04:11 PM
lt4 coupe's Avatar
lt4 coupe
Steve
What made you go solid axle?
Old Nov 22, 2019 | 05:17 PM
STEVEN13's Avatar
STEVEN13
I now have a 383 with ProCharger (not completed yet). Had I known I was going with the auto-I would have left the IRS.
Old Nov 22, 2019 | 06:10 PM
lt4 coupe's Avatar
lt4 coupe
How big of a deal is that conversion? I might have too on my '88 after it gets caged...
Do you still have the Dana 44?
Old Nov 22, 2019 | 07:20 PM
MatthewMiller
A few thoughts. It depends on how you're making that power, but my 396 with significant cam overlap is making more power than that and doesn't mind being lugged one bit. I can drive it at 60mph in 6th all day, which is 1400rpm, with no bucking and still getting 26mpg. So I wonder if your tuning at low rpm and high loads might need a bit of work?
The right gear is really going to depend on the use of the car. You specifically asked about 1/4-mile performance, so I focused a lot on that. With your power, you may bump into the rev limiter in 4th before the traps, unless you've extended the redline beyond stock. Come to think of it, I quoted you speeds based on the 6400-rpm redline of my LT4. If your car is an LT1, then redline is (I think) 6100rpm and you will top out your gears at lower speeds than I quoted.
On the highway, 6th gear will still be pretty tall with 4.11s. At 70mph it will go from 1600rpm to 1900rpm. The only gotcha with that is that if your car currently drones between 70-80mph, which is common, then you'll be putting the drone right in the range where you typically run on the highway.
Old Nov 22, 2019 | 08:09 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Worse than that. 5800RPM.
Old Nov 22, 2019 | 08:56 PM
STEVEN13's Avatar
STEVEN13
My friend did the conversion (he has a race car shop). I sold the D44.
Steve
To 3:45 to 4:11
Old Nov 22, 2019 | 08:57 PM
lt4 coupe's Avatar
lt4 coupe
You guys must be using the mobile app and not seeing my signature.
This car has a big cam, aluminum flywheel and balancer a mechanical water pump delete including single roller SBC. 28 pounds reduction in rotating mass with 110 LSA means no lugging...lol
Old Nov 22, 2019 | 09:40 PM
dizwiz24's Avatar
dizwiz24
Ive thought about this as I already get into 4th gear (trap 121) in the 1/4.
that said, am i just gonna sit and spin in 1st?
toyo proxes r888, 93 6spd supercharged afr195 comp eliminator heads, 224/236 cam
Old Nov 22, 2019 | 10:04 PM
MatthewMiller
D'oh! Nope, just oblivious to the obvious.
I forgot to mention that I too have a 13lb aluminum flywheel and a lightened GM race pressure plate. And 108* LSA with super aggressive ramps (i.e. significant overlap). Lugging isn't a problem. At all.
