ZF6 Rear Seal
Live well,
SJW
but thats a:
’will work in a pinch but is a better choice out there ?’
so if you can find a nos zf6 tailshaft seal, id use that
also- the same guy that told me th400 seal works on the zf6 told me to ‘use red loctite’ on when installing that seal in the zf6 tail shaft.
welp, a leak developed BETWEEN the tailshaft housing and the tailshaft housing/driveshaft seal.....where the red loc-tite was..
luckily i was able to Carefully smear rtv Silicone around the outside of the tailshaft seal lip/ zf6 housing interface and stop the leak.
so that being said, are we all sure the th400 is the best zf6 tailshaft seal out there (same in every way as the zf6 nos tailshaft seal) ,
or merely ’it will work in a pinch if you cant find orignal nos parts’
because that same guy who told me to use the th400 seal, the red loc-tite, also told me to use bmw castrol 10w-60 engine oil in my transmission and that about destroyed my transmission
but thats a:
http://zfdoc.com/troubleshoot.htm
What kind of oil do you use now?
Last edited by Metalface; Dec 7, 2019 at 09:54 PM. Reason: I misread the post a little
dont use bill’s outdated recommendation on castrol bmw engine oil in the zf6
Live well,
SJW
Yeah, it's the bushing that's longer is what I meant. I was hoping that a longer bushing would help with oil sealing but there's a large oil channel on the side so I suppose I'm wrong.
