What is THIS?? (PIC.)
Old Dec 11, 2019 | 06:32 PM
rollin18's Avatar
rollin18
Default What is THIS?? (PIC.)
sinmple..
What is this wire/ plug for?
coming out a sunroof hole on Pass side..
Whats this wire for?
Old Dec 11, 2019 | 06:37 PM
John Armond's Avatar
John Armond
Female socket for the sun visor mirror light plug.
Old Dec 11, 2019 | 06:38 PM
Waterloo Wonder's Avatar
Waterloo Wonder
Since I do not see a visor, I am going to guess it is wire to power a lighted mirror in the missing visor. Will help if you posted year. I do not think any Corvette has a sunroof. Targa Tops..... Yes.
Old Dec 11, 2019 | 06:46 PM
rollin18's Avatar
rollin18
Ok gotcha! TARGA'
I wouldnt have guessed visor as I do not have any... and was kind of wondering if they came that way.... i will look into sourcing 2 visors then!
thanks!
M
Old Dec 13, 2019 | 04:20 AM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
I need a couple of those female ends for my 1990 and haven't been able to find em anywhere for the life of me. I have half a mind to just cut the male ends off the visors and just twist em together with some heat shrink over them.
Old Dec 13, 2019 | 10:37 AM
383vett's Avatar
383vett
A dab of solder would work too.
Old Dec 13, 2019 | 01:41 PM
barchetta1's Avatar
barchetta1
Please dont. Jump on amazon and buy heat shrink connectors that have solder in them. Get a heat gun or preferably a hot air SMD device remover.. they are miracle workers.
Old Dec 13, 2019 | 05:43 PM
Furioso's Avatar
Furioso
Can you recommend an "hot air smd device remover?" Some of us have no idea what you're talking about. But we probably need one.
Old Dec 13, 2019 | 06:12 PM
barchetta1's Avatar
barchetta1
Okay, here is what I would recommend :
https://www.amazon.com/gp/product/B073RMRCC3/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B073RMRCC3/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.com/TXINLEI-858D-Station-Tweezers-Desoldering/dp/B07FBGFT3K/ref=sr_1_9?keywords=hot+air+desoldering&qid=1576278508&sr=8-9 https://www.amazon.com/TXINLEI-858D-Station-Tweezers-Desoldering/dp/B07FBGFT3K/ref=sr_1_9?keywords=hot+air+desoldering&qid=1576278508&sr=8-9
You can go cheaper on the hot air station but I wouldnt go much. I guess a regular old heat gun could work but being able to direct the air into a narrow stream and adjusting the temp is very nice.
I had some mice eat cables on my truck in an extremely difficult area and these things saved me. Now that I have a bunch I would use them over a crimp connector any day. Looks like you need about 138f temp to melt the solder.
I really thought I was screwed before I found these.. they worked very well. They are pretty water tight too because of the heat shrink component. When you are done you will smile because you know you did quality work. By the way SMD stands for surface mount device. They are on almost all circuit boards today Sorry I was lazy and should have been more detailed..
Old Dec 13, 2019 | 06:33 PM
Natty C's Avatar
Natty C
Hm. I've never seen those before. I would have soldered anyway, but those make things a bit easier. I'll grab some, thanks. Learn something new every day.
Old Dec 13, 2019 | 06:44 PM
barchetta1's Avatar
barchetta1
No problem.. really should work fine with a normal heat gun. I already had the desoldering station. Very neat and clean job when done.
Old Dec 17, 2019 | 10:24 PM
rollin18's Avatar
rollin18
I have another one you can have... but it has the whole plug-to plug- about 1ft. long....
To What is THIS?? (PIC.)
