96 damper install debrief; kyn
1. Why am I replacing?
I have very light 3 piece CCW wheels and as in all that is performance things get more difficult as performance increases (light wheels are harder to control). I have oscillations over 55 mph.. they come and go as I hit bumps which from my experience means loss of control.
2. How difficult were the rears?
Pretty simple and all I used was a 2x4 approx 4 ft long, a floor jack and I did have the luxury of battery impact to pull the inward nut off the bottom of the shock. I would have used a jack stand if it werent for the impact (mine are in storage now). I used the 2x4 leaned over a tire to hold the bottom of the suspension but a jack stand might have been better.. 2 upper bolts were easy though long and when I see a battery socket wrench go on sale Im buying.
3. How did the Bilsteins seem after removed?
After this many years they were still pressurized.. I sure as heck hope I find a dead one in the front.
4. Was ride height affected?
1/2" higher before settling.
5. How much did all 4 cost?
Rockauto $125 shipped to my door.. that is ridiculous.
I'll debrief on the fronts and then a drive..
Im hoping that some loss of pressure was just enough to lose control. With no velocity (important) the KYBs seem to have about 50% more compression pressure. I hope I dont need a mouthguard when Im done.
I will say this about the KYB.. the rubber bushing do not fit properly, I ended up reusing my bushing which looked to be a little hard but no cracking. Kinda let down by that.. the middle portion of the bottom bushing did not fit through the hole in the upper mount. So if I used them I may have had some horizontal movement in the upper position. Not a call I wanted to make but I made it.
Its amazing that these shocks all had pressure in them and are 25 years old with 74k miles on them.
Fixed a nasty rattle in the rear and the oscillation is gone.
They are a little "floaty" so Id probably be happier with sport bilsteins or better yet an adjustable. That, unfortunately, is going to have to wait until I get my financial situation taken care of. For $125 I am happy with the KYB's. They essentially do the job, I just dont consider them a performance damper.
Interesting note: Just because their is still positive gas pressure does not mean they are good dampers. I had some oil on the tops of all of them. Up on a shelf they go just in case the car needs to go back to original 40 years from now when they finally start to have value.
I hope this helps someone considering this economy alternative.
After another drive I will say I am very satisfied.. maybe my 14lb dog took care of the floating problem.. or the shocks broke in a little or the temperature change made a difference. I may not like these at all come 90f summer heat.
