Headlight Actuator Problem a New one to me
Old Dec 21, 2019 | 12:43 PM
s carter's Avatar
s carter
Default Headlight Actuator Problem a New one to me
We have all heard the story I turned on my Headlights and they Buzz or some other thing. Last night I turn on the headlights on one goes to work the other goes 1/2 way, we all know the next line #@$%^$ Pucks or Gears, So this morning I head out with tool's and my spare parts to knock it out I Pull it apart and find that Gears Perfect Pucks Perfect?
. Now what I did find is the Shaft that connects to the Aluminum that holds the Pucks are no longer 1 Piece not locked together. So first Question are they supposed to be locked together as 1 Piece and if so is it available.
Old Dec 27, 2019 | 06:48 PM
95BLKVette's Avatar
95BLKVette
It would really help a lot if you posted a picture of this issue.....
Old Dec 27, 2019 | 07:17 PM
s carter's Avatar
s carter
Not much to photograph, the Shaft hooked to the headlights is no longer a tight fit to the clutch assembly so everything moves. The bigger question was if the clutch & shaft where available and there Not. Scored replacement motor all fixed
To Headlight Actuator Problem a New one to me
