Balancer Hub Key?
Old Nov 17, 2002 | 02:56 PM
STL94LT1's Avatar
STL94LT1
Default Balancer Hub Key?
I just removed my balancer hub and there is a cutout in the crankshaft for what appears to be a key, but there was no key. Is the balancer hub pressed on so tight that it doesn't rotate on the crank?
Old Nov 17, 2002 | 03:34 PM
Zix's Avatar
Zix
Default Re: Balancer Hub Key? (STL94LT1)
The crank has a slot for a key, but the hub does not. When I took mine off I had a keyway machined into it and put a key in the crank. It's not a bad thing to do if you already have it off...just find a good machine shop to do it. It cost me $60 to have it machined into the hub and gives me a little extra piece of mind!
Jay
