Another thought... is there any advantage to running these low impedance injectors? I have researched using a VersaFueler for 269.00. The injectors I have (PN 17091645) are 27 lbs low impedance Rochester injectors.
There is NO horsepower to be gained on a stock motor switching injector sizes. Use the size your ECM is programmed for and drive happily ever after.
What did you do, contact Jon at fic, tap his knowledge and end up buying on eBay?
No No... just order the 26# Bosch III LT4 Customs form FIC today. Those post were just ramblings of considerations.
Actually, I spoke with Bob at FIC via email. He was very helpful. FIC does ROCK
Got to be careful with that eBay stuff. I was able to connect with the seller (Doctor Injector, Inc.) who sold me the wrong injectors. They did agree to a return with full refund. But, they did try to tell me the LT4 had low impedance injectors. Proved with data they were wrong to get my 245.00 back.
As I said Doctor Injector Shops, INC are taking the injectors back for a refund. I am pulling them out tomorrow. My Bosch III from Fuel Injector Connection are arriving tomorrow.
However in discussions with Dr INJ they insist the low impedance are compatible in my 96 LT4 Corvette, although I personally haven’t found any evidence of that. (GM PN 17091654) If the 96 Corvette PCM is capable of running Low Impedance injectors, then that leaves the possibility that there is a bad injector on the INJ2 circuit that blows the fuse when hot and operating at full rpm. The injectors all test 2.3 ohms cold and at engine operating temp. Either way they are taking them back and will test them. The car runs fine when I replace the fuse, although scanning shows misfires.
That leaves me with this question on the forum. Does any one know if Low Impedance Injectors will operate on the 96 LT4 PCM without Modification. Just curious, will know more once I replace the injectors.
I am still following because I am curious of the last question as well. Not surprised it blew a fuse based of V=IR. If resistance goes down in a constant voltage circuit, the Amps must go up. If the circuitry isn't built for the amperage, it melts down. I do hope that since you blew fuses it did it's job and protected the circuitry from an over current condition.
I believe the PCM is still good. The car runs good once the fuse is replaced. But I’m not taking a chance with another run. The Bosch III FROM FIC will be here tomorrow and we will find out.
Back from my test drive. Replacing the Rochester Injectors fixed this issue. My PCM survived the installation of the low impedance injectors.
BTW... the FIC Bosch III LT4 Cuntom 26# injectors perform perfectly.
