'90 SIR failed squib in steering column?
Old Nov 18, 2002 | 01:39 AM
dolfinwriter's Avatar
dolfinwriter
Default '90 SIR failed squib in steering column?
This one is bound to be tough--I had the SIR Infl light, so I did the TSB on the sensors, and I even had to replace one sensor.
Now I still have one remaining fault code, which is apparently for the squib itself. The local 'Vette shop gave me a Polish hand salute and said maybe the dealer can fix that as it is way down in the steering column.
:confused:
Has anyone had experience repairing/replacing these? I'm trying to fix all the problems I know about so I can sell the car. Or should I sell it with this problem also, as a known problem?
I would really appreciate any help with this one!
:flag
Old Nov 18, 2002 | 10:30 AM
dlmeyers's Avatar
dlmeyers
Default Re: '90 SIR failed squib in steering column? (dolfinwriter)
Are you getting a Code 35-Inflator Squib-Open Circuit? A code 36?
Do you have the factory service manual?
Let us know.
dlmeyers 90 coupe zf6 3 speed shocks
Old Nov 18, 2002 | 11:23 AM
dolfinwriter
Default Re: '90 SIR failed squib in steering column? (dlmeyers)
It's either a 35 or 36--I forget now which. I'll have to check my notes again, but I'm at work right now.
Yes, I do have a Helm factory service manual.
When the 'Vette shop shrugs, I'm worried!
Thanks for your help!
Old Nov 18, 2002 | 12:17 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Gordon Killebrew said that the connector for this would get dirty quite often. The fix was to clean the connector, put it back together, and wrap it with black electrical tape to keep it clean. They changed the connector later on to a weatherpack style one that would not get dirty as easily.
Worth a try....
Old Nov 19, 2002 | 02:05 AM
dolfinwriter
Default Re: '90 SIR failed squib in steering column? (Marcho Polo)
Which connector? I've had the steering wheel off, and been way down in the column to replace the sliding contact for the horn and one horn button. I saw where the line goes through for the squib.
Are you talking about a connector at the other end of the column, or one that comes out elsewhere?
To '90 SIR failed squib in steering column?
