Window regulator - needs replacement or adjustment?
Old Jan 17, 2020 | 02:27 PM
Chris Capozza's Avatar
Chris Capozza
Default Window regulator - needs replacement or adjustment?
As I'm working on my 84 C4, a new issue has arisen: when closing the passenger window, the window doesn't fully stop. Instead, I get a "clack-clack-clack" until I release the window raise switch. Thing about it is that it only happens when raising the window when the door is closed. This leads me to thing the regulator tape may not be broken (yet), but rather the window assembly may need adjusting.
What can y'all recommend?
Old Jan 17, 2020 | 03:19 PM
Kevova's Avatar
Kevova
Corvette doesn't use a tape. You need to remove door trim and see if regulator or stops are broken.
Old Jan 17, 2020 | 04:25 PM
Chris Capozza
Well, the door panel is off, but I'm not sure what it is I'm looking for.
Old Jan 17, 2020 | 04:35 PM
Kevova's Avatar
Kevova
IDK watch regulator try to see if you can determine where noise is coming from. You could search YouTube
Old Jan 17, 2020 | 04:51 PM
Chris Capozza
That's exactly what I'm doing. And that's where I found videos on the regulator tape.
Old Jan 19, 2020 | 02:58 AM
Gibbles's Avatar
Gibbles
Early vetts have the tape like the vid shows.
i don't know what's happening where your getting the clacking, but i suspect its the regulator tape.
i did the one in my car, it was broken when i bought the car.
it was not that bad of a job if i remember correctly.
i now have the later style scissor type regulator installed.
it's a huge improvement, but you have to drill holes at the bottom of your door to mount it.
i suspect you need to pull the motor and replace the tape, that plastic gets brittle with age.
Old Jan 20, 2020 | 01:43 PM
Chris Capozza
Thanks Gibbles. To be safe, I ordered a pair of the regulator tapes. If I have to replace one, the 2nd one can't be far behind ......
To Window regulator - needs replacement or adjustment?
