Code 22
Old Nov 18, 2002 | 06:35 PM
colin84vette's Avatar
colin84vette
Default Code 22
hey guys
my 84 Xfire flashed code 22 at me a couple times today. How do i check the problem out ? is it ok to drive or should i jump into my 2.8 powered fiero :confused: thanks
Old Nov 18, 2002 | 06:51 PM
greg84's Avatar
greg84
Default Re: Code 22 (colin84vette)
hi,code 22 is your tps sensor voltage low.you need a volt meter to check your voltage beteew harness conn.a and c it should read4-6 volts.the tps senor on the 84s are adjustable.good luck,greg84
Old Nov 18, 2002 | 09:08 PM
colin84vette
Default Re: Code 22 (greg84)
that sounds good gives me something to do this weekend btw how do they adjust?
[Modified by colin84vette, 2:15 AM 11/19/2002]
To Code 22
