new grinding noise
Old Jan 30, 2020 | 11:27 AM
Space387's Avatar
Space387
Default new grinding noise
While on a short drive into town my 1990 coupe developed a grinding/squeak similar to squealers dragging on a slightly warped rotor. Its pulsating and speed dependent, if mph doesn't change the pulsating speed doesn't change. I put the car up on jacks thinking I could find what was probably rubbing on a rotor or the drive shaft but nothing. put it back on the ground and drove it down the road, its quieter but still there. It gets louder when I accelerate hard and decreases when I let off. Put the car back up and ran through the gears but all I heard was silence from them. I have found a touch of slop in the rear wheel bearing, enough to go tink as you force it up/down or left right. With the wheel off and a rotor bolted on you get the same but I can't see anything moving or slop in the suspension. Any help would be appreciated.
