Comp cam = 74219
Old Nov 19, 2002 | 10:56 AM
Cratzy's Avatar
Cratzy
Default Comp cam = 74219
Can I find a roller cam from Comp cams or other brand that is equal to 74219? I am planning on building a stroker with SR on an old block and as far as I understand the 74219 won’t fit. :cheers:
Old Nov 19, 2002 | 11:03 AM
dgoodhue's Avatar
dgoodhue
Default Re: Comp cam = 74219 (Cratzy)
If your taliking about non roller 86 and earlier block, you can get it to fit with retrolifters, cam button and washer, and a 87 up timing chain.
Old Nov 19, 2002 | 11:14 AM
Caboboy's Avatar
Caboboy
dgoodhue is right on, however if you have clearance issues, LPE won't make a small base circle cam. I'd bet Comp Cams has that grind dialed in either in small or std. diameters....... :cheers:
Old Nov 19, 2002 | 02:23 PM
gtsyellow's Avatar
gtsyellow
you can probably find better, comp will custom grind about anything your heart desires. the 3313 lobe is a 218@.50 but it doesn't have as much valve lift. if you wanted a single pattern cam similar to the 219 a 3314/3314 lobe cast on a 108 centerline with 112 seperationwould perform similar with a little more high rpm performance. the 3314 is a 224@.50 lobe with a really steep ramp angle, lift is .502 on a 1.5 arm or probably .530 something on a 1.6.
Old Nov 20, 2002 | 03:28 AM
Cratzy's Avatar
Cratzy
Default Re: Comp cam = 74219 (gtsyellow)
OK, thank you very much. That is exactly what I wanted to know.
Best regards
:cheers:
To Comp cam = 74219
