C4 convertion from auto to manual ?
Old Nov 19, 2002 | 07:35 PM
qkvette's Avatar
qkvette
Default C4 convertion from auto to manual ?
Has anybody ever attempted this ?
If yes, how much did it cost ?
just checking if there are other options before tranny rebuild.
thanks,
joel
Old Nov 19, 2002 | 08:34 PM
crznL98's Avatar
crznL98
Default Re: C4 convertion from auto to manual ? (qkvette)
-=Jeff=- has done the conversion, and I am trying to finish my own car. As long as you get all the parts, and they are in good condition, it's not too much work. However, it is expensive. To get all of the parts you need, in good working order, my guess is probably about $5,000. You will also need to cut holes in your firewall for the clutch master cylinder and cut a hole in your transmission tunnel for the transmission. I haven't finished my own car because I don't have enough free time, and I also rebuilt everything, but if your car is in good working order, and you have the means and time, don't be afraid to do it since you've already invested money in your car anyway.
Old Nov 19, 2002 | 09:29 PM
ittlfly's Avatar
ittlfly
Default Re: C4 convertion from auto to manual ? (crznL98)
This topic has appeared may times. The main problem seems to be that the trans. tunnel on the auto is different than that of the stick. The only way to make the transition is to find a wrecked stick , cut out the tunnel area and install it on your car after you remove yours. A major PIA let alone the expense. It was the consensus that it would be much cheaper just to go out and buy a stick.
Old Nov 19, 2002 | 09:50 PM
dgoodhue's Avatar
dgoodhue
It maybe more economical to swap you parts into a 6 speed car and then sell your car. As I see you have a bunch of mods, it maybe be an option to buy a wreck 6 speed parts car and then swap what you need and then part it out.
Old Nov 19, 2002 | 10:09 PM
tommelton's Avatar
tommelton
Default Re: C4 convertion from auto to manual ? (dgoodhue)
I did this to my 86. Search the archive for my username, tommelton, also look here for the tunnel pics...towards the bottom.
http://home.attbi.com/~tmelton/86z51.html
Let me know if you cannot find the archived posts.
Tom Melton
82 CE
86 Z51 Coupe with 1996 ZF6
Old Nov 20, 2002 | 09:05 AM
snaketr's Avatar
snaketr
Default Re: C4 convertion from auto to manual ? (tommelton)
I did this to two vettes. It is not hard, but its the little things that can be a PITA. If I had to do it again, I would shifting gears is much better than putting it in D. Also I happen to like the flat dash, and finding a 89 with a ZF is almost impossible. Look at Tom Melton's pic he has some good ones in there that you should look at.
Old Nov 20, 2002 | 02:03 PM
qkvette's Avatar
qkvette
Default Re: C4 convertion from auto to manual ? (snaketr)
thanks for all the info guys.
i would really like to go this route, but as you guys pointed out, it is alot of work and expensive.
i guess i'll go for the cheapest route, and have my tranny redone again.
joel
To C4 convertion from auto to manual ?
