Reverse gear on an auto
Old Nov 19, 2002 | 09:58 PM
aroulette's Avatar
aroulette
Default Reverse gear on an auto
I have an automatic and when its cold it has a problem engaging reverse. No problems when out driving it around. Just when I get started. I shift into reverse and nothing, I rev it and it as if its in neutral, but it will finally go into reverse. Any ideas?
Old Nov 20, 2002 | 01:37 AM
aroulette's Avatar
aroulette
Default Re: Reverse gear on an auto (aroulette)
no help?
Old Nov 20, 2002 | 01:46 AM
VetteNoob's Avatar
VetteNoob
sorry, no info to help, but sounds like you need to have someone take a look at it. have you checked the tranny fluid? does the symptoms change with air temp?
Old Nov 20, 2002 | 03:32 AM
merrick's Avatar
merrick
If it also has a cold delay to first gear, then your torque converter is draining fluid back to the pan(check valve leaking). If it is only in reverse, not sure, but a little time and luck, it may cure itself.
Old Nov 20, 2002 | 11:14 AM
c4cruiser's Avatar
c4cruiser
Service manual has a number of possibilities; components sticking, forward clutch not releasing, problems in oil pump assembly, valve body and auxiliary valve body problems, lo and reverse clutch problems.
I would have it checked out at a reputable transmission shop. When was the last time you had a fluid and filter change? Might be time for some maintenance work!!
Old Nov 20, 2002 | 12:52 PM
aroulette's Avatar
aroulette
Default Re: Reverse gear on an auto (c4cruiser)
not sure when the transmission was maintained
To Reverse gear on an auto
