Hey dizwiz, thanks for the reply, did you ever try the same thing using Tunerpro and the Autoprom to add the AFR data to the Autoprom data stream?
i never used autoprom
i used To use tunerpro for tuning but not data logging
i used to use tts datamaster v351 for datalogging, and would ‘hand calculate’ the wideband afr off the ac pressure (i had figured out a linear regression formula off it). This was a PITA when on the dyno bc it took time to do and time is $$.
i stopped using datamaster when datamaster stopped supporting it.
datacat is nice bc theyve already done the conversion and give you 2 other options as well for additional wideband sensors (oil preasure and oil temp)
