HEADER GASKET HELP NEEDED...
Old Nov 20, 2002 | 10:01 AM
republicanhunk's Avatar
republicanhunk
Default HEADER GASKET HELP NEEDED...
Thanks for looking...I am trying to replace my old cardboard header gaskets with some more permanent copper ones and I am finding difficulty getting the header bolt holes to line up properly with the holes in the head. They are only the smallest bit off but that makes it impossible to get the bolts started. I thought about letting the headers heat up and then maybe they will expand just enough to get the bolts started. I would really appreciate any best practices anyone may have. thanks :confused:
Old Nov 20, 2002 | 10:07 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: HEADER GASKET HELP NEEDED... (republicanhunk)
Are they still attached to the rest of your exhaust system on the bottom? If so take that loose and that will allow you to manipulate your header some. Also the Mr. Gasket Copper gaskets that I used had "ears" on the outside bolts that would allow you to get them in there easily. Basically you get the header in place somewhat and start the extreme outer bolts. Then you can slip the gasket behind it and tighten it up a little bit. This should pull it in place enough to get the other bolts started.
Helpful hint. I used a little bit of ARP assembly lube on the header bolts last time I put them in and it made life easier. They screwed in with a lot less resistance and it let me get them tighter with less effort. Months later none have backed out at all.
:cheers:
Old Nov 20, 2002 | 10:10 AM
republicanhunk
Default Re: HEADER GASKET HELP NEEDED... (Nathan Plemons)
thats a good idea..one of my buddies suggested jacking them up slightly and that would make a difference as well. thanks for your ideas :flag
To HEADER GASKET HELP NEEDED...
