Plug and play LS swap, does anybody make one?
, I really don't care about the fuel mileage indicator or what ever else that dropped off my digi dash. No sure why this has to be such a big issue, not everyone has to be on the same page. Heck you could put a hemi under the hood and it would work.If you really wanted all the new car stuff but in an old car, its going to be alot more complex and $$$ costly. I prefer the big smile on my face each time I drive my car now. I rather put all that extra money into the engine, myself and keep the smiles coming.
I don't like the C5 body style which means I would have to get a C6 and a decent one of those costs a lot more money than I want to spend. A C7 is completely out of the question because that costs way more money than I can afford. I really like the body style of the '91 to '96 C4 (mine is a '96)
and I'm willing to spend a few grand (not including the cost of the engine of course) to do the conversion correctly.
For me, it's the newer toys and the ability to upgrade and buy stuff for it. Tired of hearing "Obsolete". Since I honestly don't care about how the body looks, I would take a C7 with a C4 body kit for all I would notice.
Not sure how much that "few grand" is but none of the shops I talked to would give me a hard limit and I don't want to be halfway done and they ask for more money because now I am behind the proverbial 8 ball.
All started around the time he was getting sponsored parts.
There are several people piggybacking the stock gen 4 ECU with the Holley Terminator X and keeping factory functionality on everything else, gauges and all.
I've seen the guys at Horsepower Factory in Houston doing it a lot lately as well.
Obviously some people just like the feeling of "new", there's a gratification in getting something new. but I and several others have found the new cars aren't as fun to drive. If you just like to brag about them, gun it once in a while for a rush, they'll appeal to you. But if you like to take corners and get a rush, they're not that great.
Yeah, there's definitely options to do it, just a matter of having the knowledge and skills to do it. If you want to buy something plug & play to do it, that costs money. If you're willing to do development on your own, then you're just spending time, and if its a hobby it's "getting to enjoy time".
Unless you're aiming for some 600+whp boosted nightmare, the LT is just as capable as the LS, and way cheaper. And it's not like the LT can't be boosted either, you can DEFINITELY put boost into an LT and make crazy power. Plus, the LT is a little lighter, and so if you want to maintain that corvette handling, that's a good thing. Sure, there's a displacement advantage, but that's not offset IMO by the huge expense of swapping the motor.
If w were talking L98 cars, things would be a little different. But the LT1 has a ton of potential and so there's really no need to swap it.
Its been done for almost 30 years now. I'm not sure why so many people suddenly think its some uncharted territory.
I piggybacked my Neon SRT-4 with Megasquirt-II back in 2007 and daily drove it for years. Just bought a generic unterminated harness and tapped into the stock harness with it. No extra costs.
As far as gen 3 stuff:
Whats needed for the LS swap in the later LT corvettes would depend on what they need from the factory ECU to function.
The LS ECU (factory or aftermarket) will control all 8 coils and injectors, and will need MAP, Coolant, IAT, cam, crank, TPS.
MAF, O2 sensors, IAC are all optional.
You can get a 3 wire LS1 coolant temp sensor and splice it to where it needs to go for the factory C4 stuff to work.
You can use the factory LS oil pressure sensor, the ECU doesn't need it on the Gen 3 stuff. You can use your old oil temp sensor with an adapter
If you use your factory trans, nothing needs changed for the speedo to work.
Nothing needs to be changed for the fuel gauge. That leaves you with the tach, but there are a few ways to handle that one.
